usb loader gx wii version 4.3e
  • helpmewii
    • Feb 2012
    • 20
    Please help, i am new to this and have just soft mod my wii. I need some help with usb loader gx though. when i launch it through homebrew channel it just gives error message needs unstubbed cios 222 v4 or 249 v9+
    1 found
    222=0
    249=0
    I have no idea where to start or how to sort this out.
    Any help with this would be great. I am a laymen so please if you can help simle step by step guides to help me sort this out.
    Thanks in advance
  • Keithuk
    • 2264
    What you need to do is use MMM which you can find in Usbloader gx 2.3 r1128 and d2x v7 with mmm 13.4 if you don't have it. Then you need to install all the wads in d2x v7 final that has all the wads needed for the USB Loaders.
    Keith
    2010 Golf GTD (170)
    • helpmewii
      • Feb 2012
      • 20
      Still more help
      Thanks keith for your help so far, but still need more. I have downloaded and extracted the files you said, now how do i get them on my wii. I know this is probably basic for you but i still don't know exactly how to do it. Your help is much appreciated.
      • ronnie5
        • Dec 2011
        • 35
        They need to go on an sd card in the wad folder stick it in the wii and then use homebrew channel and select mmm (multi mod manager) and install through that.
        • Keithuk
          • 2264
          If you don't have MMM in the apps folder of the SD card extract it from Usbloader gx 2.3 r1128 and d2x v7 with mmm 13.4. Add all the wads out of d2x v7 final into the wad folder.
          Startup your Wii and click on the Homebrew channel. Depending on how many apps you have on the card it should be the first one Multi-Mod Manager 13.4. Navigate down the menu with the big + button to WAD Manager and press 'A'. In that screen will list all wads in the wad folder. If you have loads then navigate down to the ones listed in d2x v7 final and press the small + button which puts a green tick next to the name, do that for all of them them press 'A'.
          The next screen will list all wads you want to install, press 'A' to install them and watch the screen to see it says OK after each one. If you've missed one press 'B' and go back to select it. If it doesn't say OK go back with 'B' and select it again. They normally install the first time.
          All the buttons and functions are shown at the bottom of each screen.
          Keith
          2010 Golf GTD (170)
          • happy_highlander
            • 3535
            Almost all the files I have uploaded including this one is designed to be extracted to an empty sd card to reduce the chance of errors or confusion and include mmm an apps folder and a wads folder with relevant wads
            • helpmewii
              • Feb 2012
              • 20
              still more help required
              Thanks to all who have tried to help me so far. I have downloaded and extracted Usbloader gx 2.3 r1128 and d2x v7 with mmm 13.4 to a formatted sd card. When i put it into my wii it does not show up, what am i doing wrong?
              • Keithuk
                • 2264
                I don't know what your doing wrong as Usbloader gx 2.3 r1128 and d2x v7 with mmm for installation.rar has an apps and a wad folder inside so those are in the right place.
                What did you use to format the SD card Windows?
                That always works for me but there are some users on here that that doesn't work, I've got no idea why not. So they tend to use SD Card Formatter. Now to me you don't have to keep on formatting the card everytime just delete all files and folders. Oh it must be formatted FAT32 which Windows does by default on small drives.
                Keith
                2010 Golf GTD (170)
                • helpmewii
                  • Feb 2012
                  • 20
                  more help
                  Thanks Keith for your help with my problem, you are a god. I will explain exactly what i have done. I first loaded letterbomb on to my wii which installed the hbc. Then i downloaded and extracted hack pack part 2 which i got from mediafire. When i put this in to my wii i get 4 things come up. mmm-priloader-cios installer-and media player. I downloaded on the wads in the wad folder (49 i think) i then installed pri loader. After this i formatted my sd card (using windows) and downloaded hack pack part 3, again i got this from mediafire. Putting this into my wii i get 5 things come up. Usb loader gx but when played gives me the errors which i said before-Gc Backup launcher-Homebrew browser-Mplayer ce and NeoGamma- So the mmm has gone. SO i took the sd card out formatted it again. I then downloaded and extracted Usbloader gx 2.3 r1128 and d2x v7 with mmm 13.4, put the card back into my wii and all i get is hbc screen with bubbles on no apps or anything. Hope this is clear what i have done. I hope this gives you more info in to what i have done and hope you can help me solve this problem.
                  Thanks helpmewii
                  • helpmewii
                    • Feb 2012
                    • 20
                    more help
                    Thanks Keith for your help with my problem, you are a god. I will explain exactly what i have done. I first loaded letterbomb on to my wii which installed the hbc. Then i downloaded and extracted hack pack part 2 which i got from mediafire. When i put this in to my wii i get 4 things come up. mmm-priloader-cios installer-and media player. I downloaded all the wads in the wad folder (49 i think) i then installed pri loader. After this i formatted my sd card (using windows) and downloaded hack pack part 3, again i got this from mediafire. Putting this into my wii i get 5 things come up. Usb loader gx but when played gives me the errors which i said before-Gc Backup launcher-Homebrew browser-Mplayer ce and NeoGamma- So the mmm has gone. SO i took the sd card out formatted it again. I then downloaded and extracted Usbloader gx 2.3 r1128 and d2x v7 with mmm 13.4, put the card back into my wii and all i get is hbc screen with bubbles on no apps or anything. Hope this is clear what i have done. I hope this gives you more info in to what i have done and hope you can help me solve this problem.
                    Thanks helpmewii
                    • Keithuk
                      • 2264
                      The bubbles screen means there is no SD card inserted or there are no apps in the apps sub folders with the different boot.dol files in there.
                      So you formatted it FAT32 in Windows then, which Windows are you using?
                      Keith
                      2010 Golf GTD (170)
                      • helpmewii
                        • Feb 2012
                        • 20
                        more help
                        windows xp
                        • ck-ok
                          • 2592
                          windows xp
                          why not just use http://www.digital-kaos.co.uk/forums...indows-170234/ select "w" for wizard then virgin install download files and tut skip the homebrew channel install as you have it already mod it and job done.
                          • Keithuk
                            • 2264
                            Well I used WinXP and Vista and SD card always format straight of at FAT32 in both of them.
                            Keith
                            2010 Golf GTD (170)
                            • helpmewii
                              • Feb 2012
                              • 20
                              usb loader
                              I have finally done it. Having more time on my hands yesterday i followed Keiths instructions and got usb loader to work. Thanks to all of you out there for help with this issue i had. Now my next question to you genius out there is this, once i have a game on my external hard drive (which is only a 4 gig memory stick at the moment) can i transfer it from my memory stick to my computer and save the game in a file or something. Thanks in advance
