does this work with WiiFlow?
usb loader gx wii version 4.3e
No they don't Keith ????????? there are loaders which are designed to run on hermes cios which are 222,223 and 234 and can 't use the waninkoko cios which are 245 to 251....Usb loader gx is the only loader that can effectively use both sets but only if you use the rodries mod version of the hermes cios.........Hermes cios loaders are can almost always only read wbfs format as well. The best known of the hermes loaders is Uloader which until the development of the rodries mod and gx.2.3 was the only loader you could play rock band games with and have all instruments workingComment
Does what work on Win 7?
All my USB Loader use 249.
I have 222, 223 and 234 installed but I don't use them.Keith
2010 Golf GTD (170)Comment
You may not use them keith but don't tell people all loaders use the same cios when they don't. To give the wrong information is worse than to give no information. Most people come on here to get answers because they don't understand the process. You also still recommend wbfs a format that works but works best hermes, so to recommend using waninkoko cios you should also be recommending fat 32 as they were designed to be used together as were hermes and wbfsComment
I aren't arguing I just know what works on my 4.3 system for the past 14 months.
Providing they install IOS36, IOS236, Full Cios wad pack and d2x v8 Final wad pack in that order any USB Loader should work.
Along with the USB Loader they want to use.Keith
Have you even looked at the contents if the files you are linking to. Why would anybody want to install d2x v8 after the full cios wad pack when the full cios wad pack is exactly what it saysI aren't arguing I just know what works on my 4.3 system for the past 14 months.
Along with the USB Loader they want to use.Comment
Yes I know d2x v7.0 is in Full Cios wad pack but so what v8.0 will overwrite them if they are installed afterwards.Keith
Sorry mate wrong again.....the full cios pack used to contain d2x v7 but as with all my files If they need updated and are not specifically named I do keep them updated so if you were to download the cios pack again you will find it contains v8 and has done for a while now.......I do tryComment
Well the last Full Cios wad pack had d2x v7.0 in either way is still doesn't matter.
The current Full Cios wad pack has d2x v8.0 in it.Keith
Welcome to DK.
Well if the correct wads are installed post a sysCheck as instructed in that link and your USB drive is compatible.
USB Compatibility List
USB Devices Compatibility List - WikiTemp USB powered drives are very hit and miss.
Then I would say you haven't loaded the games on the drive correctly, how have you done this?Keith
help??
im using usb loader gx 3.0 and cIOS 2.3 ive used all the guides i can find to install this on to my wii console but when i load up usb loader it says cant find any cios and then says cant find usb device even though it is plugged into the slot closest to the edge of the wii.
i installed the ios36 on to slot 250 as instructed but still nothing
please help me
thanks allComment
