usb loader gx wii version 4.3e
  • Keithuk
    • 2264
    #31
    Originally posted by curkri
    I downloaded the ios 236 wad file but I am not sure how to install it. I can't use the wad manager it just says "Final Status - 1 did not complete"
    Are you using Multi-Mod Manager (MMM) 13.4?. You install it the same as you install any wad just add the wads to the wad folder and select them from WAD Manager.
    MMM is the only WAD Manager that works for me with one pass.
    There is WAD Manager 1.7 if you want to try that.
    Keith
    2010 Golf GTD (170)
    • curkri
      • Mar 2012
      • 8
      #32
      Well thanks for your time anyways guys. If anyone can think of anything I might have forgot to do before I started the wad installs.... would Homebrew or bootmii need to be a certain type? or is there something else that MUST be configured first?
      For the time being I cannot install a single wad without the "Final Status - Did not complete" message.
      • happy_highlander
        • 3535
        #33
        Post a syscheck please but it sounds like you are trying to install wads into ios 58 if you do not have ios 236 reload to ios 249 instead
        • curkri
          • Mar 2012
          • 8
          #34
          Ok I have sorted it, I used an alternative IOS236 installer (Ios236 - GAF's Wii Homebrew Tutorial). After that all the wads installed fine!
          So my external hdd with my ISOs, does it need to be formatted as WBFS?
          • ck-ok
            • 2592
            #35
            Ok I have sorted it, I used an alternative IOS236 installer (Ios236 - GAF***039;s Wii Homebrew Tutorial). After that all the wads installed fine!
            all this could of been avoided if you had followed a tutorial use http://www.digital-kaos.co.uk/forums...indows-170234/ to write you a tutorial and download your files for you.
            • aprasevic
              • Mar 2012
              but are we going to lose some function of ds when we do it
              • happy_highlander
                • 3535
                #37
                What ?????????????? why would modifying your wii lose you function of your ds.........If you mean using pokemon then no not if you have the original pokemon game in your ds but if you are using a flash cart in your ds then forget about syncing pokemon with your wii the flash cart is picked up by the wii
                • curkri
                  • Mar 2012
                  • 8
                  #38
                  Ok so it is working, I am finally playing wii games through my usb hard drive
                  Will getting rid of bootmii stop me from using USB Loader GX or can it be removed without a problem now that all modding has been completed? Its just a little bit of a pain dealing with it when I boot my wii up now!
                  • happy_highlander
                    • 3535
                    #39
                    You can remove the file from the sd card now it's modded or you can just rename the folder i.e. bootmii1 or anything that isn't "bootmii" I would keep the word bootmii in there somewhere though just do you know what it is.
                    • curkri
                      • Mar 2012
                      • 8
                      #40
                      yeah I thought renaming it would be best.... thanks very much for your time guys!
                      • march86
                        • Apr 2012
                        download games
                        How can I download wii games using usb?
                        • randallflagg
                          • 27
                          #42
                          You cant download Wii games using USB. If your Wii is softmodded you can play your back-up games from your USB. See Wii USB HD Guide
                          • kerouz
                            • Apr 2012
                            • 6
                            #43
                            Thanks guys. Having this exact problem.
                            So, do all files from the Homebrew installation end up on the Wii's internal memory?
                            Does it launch the apps from the SD card or internal?
                            • randallflagg
                              • 27
                              #44
                              Which problem specifically ?
                              • kerouz
                                • Apr 2012
                                • 6
                                #45
                                I'm getting the error message that I needs unstubbed cios 222 v4 or 249 v9+
                                I've installed the wad files using MMM. Finally got the 7 wads to work as I was getting failed installation messages, then realised I was loading with the wrong iOS.
                                But now I realise that when I first installed HBC I had about 50 of the wad files fail and just didn't realise what that meant at the time.
                                So I'm still getting the unstubbed bios error message.
