usb loader gx wii version 4.3e
  • randallflagg
    • 27
    #46
    can you post a syscheck ?
    • Keithuk
      • 2264
      #47
      Welcome to DK.
      Originally posted by kerouz
      Thanks guys. Having this exact problem.
      So, do all files from the Homebrew installation end up on the Wii's internal memory?
      Does it launch the apps from the SD card or internal?
      Exactly which problem are you having?
      Now you posted in a usb loader gx wil version 4.3e thread so I'm assuming you have a 4.3 Wii and your having problems running USB Loader GX?
      Yes the Homebrew installation goes Wii's internal memory anything else you want adding goes on the SD card then you can add Forwarders so they are all show on the Wii menu.
      I will wait until you tell us the problems your having before I will tell you the fixes needed.
      Keith
      2010 Golf GTD (170)
      • kerouz
        • Apr 2012
        • 6
        #48
        Sure. What do I need to do?
        And, yes, I'm running 4.3E. Had to use the Indiana_PWNS method as Letterbomb's site seems to be down.
        Thanks for the help guys.
        • randallflagg
          • 27
          #49
          download this: Digital Kaos - Downloads - sysCheck v2.1.0 Beta 17
          Open/unzip File and copy it to the Apps Folder of your SD card.
          SD should look like this: sd:/apps/syscheck
          Insert SD card in Wii and run app from HBC (homebrew channel)
          It will create a .csv file onto the root of the SD card.
          Exit to System menu and remove the SD card
          Insert the SD card in your computer and copy the .csv file to your computer.
          Open the .csv document, copy the info into wordpad + post here.
          • Keithuk
            • 2264
            #50
            Ok so you've softmodded your 4.3 Wii. Did you do a NAND backup and have you installed PriiLoader 0.7? LetterBomb came out in July last year and I've never had any problems accessing it.
            To get the USB Loaders to work you need to install all 7 wads in d2x v7.0 Final and install them properly this time with MMM.
            As randallflagg says you could do with posting a sysCheck v2.1.0 Beta 17 report as instructed in that link then we will be able to see which other wads are missing.
            This should get you up and running then you would need to install the Forwarders for the USB Loaders you want to use.
            Now that you've softmodded your 4.3 you can now use larger SDHC cards.
            Keith
            2010 Golf GTD (170)
            • kerouz
              • Apr 2012
              • 6
              #51
              Here's my syscheck output:
              sysCheck v2.1.0b17 by Double_A and R2-D2199
              ...runs on IOS58 (rev 6176).
              Region: PAL (original region: AUS)
              System Menu 4.3E (v514)
              Priiloader installed
              Drive date: 2006.05.26
              Homebrew Channel 1.0.0 running on IOS58
              Hollywood v0x11
              Console ID: 69240260
              Boot2 v4
              Found 95 titles.
              Found 54 IOS on this console. 5 of them are stub.
              IOS4 (rev 65280): Stub
              IOS9 (rev 54321): Trucha Bug
              IOS10 (rev 768): Stub
              IOS11 (rev 54321): Trucha Bug
              IOS12 (rev 269): No Patches
              IOS13 (rev 273): No Patches
              IOS14 (rev 520): No Patches
              IOS15 (rev 523): No Patches
              IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
              IOS17 (rev 775): No Patches
              IOS20 (rev 54321): Trucha Bug
              IOS21 (rev 782): No Patches
              IOS22 (rev 1037): No Patches
              IOS28 (rev 1550): No Patches
              IOS30 (rev 54321): Trucha Bug
              IOS31 (rev 3608): No Patches
              IOS33 (rev 3091): No Patches
              IOS34 (rev 3348): No Patches
              IOS35 (rev 3349): No Patches
              IOS36 (rev 54321): Trucha Bug, ES Identify, NAND Access
              IOS37 (rev 3869): No Patches
              IOS38 (rev 3867): No Patches
              IOS40 (rev 3072): Stub
              IOS41 (rev 3607): No Patches
              IOS43 (rev 3607): No Patches
              IOS45 (rev 3607): No Patches
              IOS46 (rev 3607): No Patches
              IOS48 (rev 4124): No Patches
              IOS50 (rev 54321): Trucha Bug
              IOS51 (rev 4864): Stub
              IOS52 (rev 5888): Stub
              IOS53 (rev 5406): No Patches
              IOS55 (rev 5406): No Patches
              IOS56 (rev 5662): No Patches
              IOS57 (rev 5661): No Patches
              IOS58 (rev 6176): USB 2.0
              IOS60 (rev 54321): Trucha Bug
              IOS61 (rev 5662): No Patches
              IOS70 (rev 54321): Trucha Bug
              IOS80 (rev 54321): Trucha Bug
              IOS90 (rev 54321): Trucha Bug
              IOS202[60] (rev 65535, Info: hermes-v5.1): Trucha Bug, NAND Access, USB 2.0
              IOS222[38] (rev 65535, Info: hermes-v4.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
              IOS223[38] (rev 65535, Info: hermes-v4.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
              IOS224[57] (rev 65535, Info: hermes-v5.1): Trucha Bug, NAND Access, USB 2.0
              IOS236 (rev 54321): Trucha Bug, ES Identify, NAND Access
              IOS245[37] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
              IOS246[38] (rev 21007, Info: d2x-v7final): Trucha Bug, ES Identify, NAND Access
              IOS247[53] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
              IOS248[55] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
              IOS249[56] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
              IOS250[57] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
              IOS251[58] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
              IOS254 (rev 65281): BootMii
              BC v6
              MIOS v10
              Report generated on 2012/04/18.
              • Keithuk
                • 2264
                #52
                That sysCheck looks pretty good to me its nearly an exact copy of mine.
                Keith
                2010 Golf GTD (170)
                • kerouz
                  • Apr 2012
                  • 6
                  #53
                  So 222 and 249 are there?
                  Even though I'm still getting the missing cios message?
                  What are the cios files exactly?
                  • Keithuk
                    • 2264
                    #54
                    cIOS is custom Input Output System. Providing you have installed the d2x v7.0 Final which that sysCheck report is showing then you should be ok. I don't have my sysCheck.csv with me so I can't check which base numbers mine is using on 222. I've never had any missing cIOS's when I've softmodded the 5 4.3's that I've done.
                    The dx2 only installs IOS245 to IOS251 as that sysCheck report shows.
                    If you want to install 222 then install the wads in Digital Kaos - Downloads - Full Cios wad pack
                    Have you put some games on an external USB drive and tried USB Loader GX?
                    Keith
                    2010 Golf GTD (170)
                    • kerouz
                      • Apr 2012
                      • 6
                      #55
                      Ran through this youtube video and it's working now:
                      http://www.youtube.com/watch?v=kADXJj1Pydk
                      • bjd
                        • Apr 2012
                        Originally posted by ck-ok
                        why not just use http://www.digital-kaos.co.uk/forums...indows-170234/ select "w" for wizard then virgin install download files and tut skip the homebrew channel install as you have it already mod it and job done.
                        I have managed to install homebrew and bootmii from letterbomb but can't get anything working will modmii 4.3.4 sort this. Apologies if his makes no sense but i'm new to all this. Many thanks
                        • Keithuk
                          • 2264
                          #57
                          Welcome to DK.
                          Well if you've installed Homebrew and ModMii using LetterBomb then you must have a 4.3 Wii, did you install ALL 3 options and Prepare the SD card so you can do a NAND backup?
                          Now you have HBC you have the basic softmod what you need to do is sort out why you needed to softmod your Wii and get those apps installed. The general reason to softmod is so you can play backup games from a CD or external hard drive.
                          It maybe a 4.3 Wii now but what was it originally as Wii's 2009 and after won't play burnt games with NeoGamma. Type in the Wii serial number into Wii Drive Chip Database to see when it was made.
                          The other option is to use one of the three main USB Loaders, USB Loader GX, CFG USB Loader or WiiFlow. The best and the popular one is USB Loader GX there are many threads on here that talk about it. USB Loader GX
                          What you need to do to run any USB Loader is install d2x v7.0 Final there is d2x v8.0 in the download section but you won't need that at the moment.
                          You can install all the wads with Multi-Mod Manager [MMM] 13.4.
                          If you have any problems you could post a sysCheck report as instructed to see which wads you have installed and what type.
                          Keith
                          2010 Golf GTD (170)
                          • joemizzle81
                            • May 2012
                            i try to download what u guys post....wont let me...says i dont have permission.....please help...i want to get my girlfriend mario all stars and since i cant find it to buy i want to emulate it...any help would be appreciated...
                            • Keithuk
                              • 2264
                              #59
                              Welcome to DK Joe.
                              Originally posted by joemizzle81
                              i try to download what u guys post....wont let me...says i dont have permission.....please help...i want to get my girlfriend mario all stars and since i cant find it to buy...
                              This is your first post so you'll have to wait a bit.
                              You can't find mario all stars bull.
                              Keith
                              2010 Golf GTD (170)
                              • serviceexpert43
                                • May 2012
                                Works great.
