Well you need to do a bit more reading.
usb loader gx wii version 4.3e
Same here.. In HBC it says that I have IOS 58 v24.32. Do I need to update it to IOS 222 or something?Originally posted by newmarchJust posting once so that i can download the archive:
Usbloader gx 2.3 r1128 and d2x v7 with mmm 13.4Comment
Welcome to DK.
Well you can always post a sysCheck as intructed in that link then we can see which IOS's are missing.
If you want IOS222 then install Full Cios wad pack. After that if USB Loader GX still doesn't work then post a new sysCheck.Keith
2010 Golf GTD (170)Comment
I tried to run the syscheck and this is what I got.Welcome to DK.
Ohh.. I did the modmii thing and installed all the wad stuff. So the syscheck is kind of out of date.
It looks like the USB loader works now.
One last thing.. Do I need to have the SD card in the Wii all the time or is it possible to just copy the files over to a USB or HD?Attached FilesLast edited by OddErikT; 20 December, 2012, 08:17.Comment
Welcome to DK.
That sysCheck is of a Wii thats only been softmodded and nothing else. If that sysCheck is old why have you posted it when its got todays date at the bottom. When you post a sysCheck please do it as instructed in sysCheck.
Now you either post a new current sysCheck or read through these to make sure everything is covered.
The SD card is only for storing apps, settings and game pictures. If your using a USB Loader it has to be inserted.
You add games to a mains powered external USB drive not to an SD card, there are plenty of instruction on here.
You need PriiLoader installing to block online and disc updates.Keith
That looks ok to me.
If you want to remove the IOS16 stub download my cIOS16-v257.zip from http://www.digital-kaos.co.uk/forums...9/#post1807800 I added yesterday and put it in the wad folder on the SD card. Run Homebrew and install just that wad by selecting it with the + button that will put a greeen tick next to it. Then press 'A' then 'A' again and watch for the Installed OK message.Keith
Get an SD card, make a folder called 'Apps' and place the files in there. Then insert the SD card into your wii and run the homebrew channell - the apps will show upComment
Welcome to DK.
That post was made a year ago and I do give instructions.
It seems like your posting just so you can download things. Actually the apps folder should be lowercase else it won't work.Keith
