navigate down to system menu hacks and select it then enable region free everything then enable block disc updates then enable block online updates and save settings and then select system menu
ok go back to the main wii menu and launch hbc then press the home button and tell me what version it is and what ios it is using (top right hand corner) and I'm sure you'll tell me if it's upside down
ok you need to reinstall hbc it's on the wrong ios...it usually is. Start hbc then go to hackmii installer if it's not on te first page press the arrow till you can see it then load it and press "1" when it comes up then make sure it is on ios 58 and install hbc just as you did the first time
is it now on ios 58 if so you are almost done first we need to make sure darkcorp has gone for good put a backup game disc into your wii and see if it will load from teh disk channel
put disc in, it went to the disc channel, i pressed start but then it went black and said an error had occured and i had to eject disc and power off wii
ok thats it gone take the sd card out the wii and put it into the pc and rename bootmii1 back to bootmii and put it back in the wii. Switch the wii on and using the power button navigate to the cogs then press reset to select then press reset again in the next screen to do a new nand backup allow it to overwrite the existing nand file and make another cuppa while does what it has to but make sure it verifies.
