Wii 4.2E softmod tutorial. Easy to follow guide.
  • rev0luci0n
    • May 2010
    • 4
    #616
    Thanks!
    Have successfully softmodded my wii and have homebrew up and running.
    I own the original Wii Fit Plus, and it's asking to install an update.
    What is the best way to disable games asking for updates?
    • Timmaa
      • 88
      #617
      Originally posted by rev0luci0n
      Thanks!
      Have you installed priiloader? I'm sure there's a configuration setting in there that allows you to disable DVD updates?
      • Cornholio
        • May 2010
        • 14
        #618
        Sry but it dont work. I waited for 10min.
        And it cant mount the dvd at all so why try waiting on the Opening Stream thingy?
        Why wont it work? What does DVD Error -2 mean?
        Why cant I play dvd's nor burn em games and play xD
        • dirtydonki
          • May 2010
          • 37
          #619
          DVD Error -2 is a common PC error "Cyclic redundancy check - data error". It basically means the DVD is unreadable.
          Are you getting this error on your Wii?
          I have been at modding my 4.2e Wii for hours now and just can't seem to get past the CIOS stage. It just hangs once I try to reload Bootmii again now.
          Any advice much appreciated.
          __________________________________________________ ______
          SKY TV
          Never before in history has so much been paid by so many for so little.
          • ck-ok
            • 2592
            #620
            Thanks!
            timmaa is right install preloader and block disc and online updates and set preloader to boot to system menu Digital Kaos - Downloads - preloader-v02-rev32
            • ck-ok
              • 2592
              #621
              Originally posted by dirtydonki
              try a different sd card and are you getting any error number?
              • ck-ok
                • 2592
                #622
                did you install dvdx when you install homebrew channel? its worth going back and redoing it to make sure
                • Cornholio
                  • May 2010
                  • 14
                  #623
                  Yes I installed Homebrew channel, then directly after DVDX, I tried to do it the other way to. the DVDX first. And then again Homebrew and then DVDX
                  Still I get DVD Mounting Error in Mplayer and when going in to File/DVD Video and Play DVD and it says Opening Stream, it just shows the background itself removing all the text.
                  I still dont work
                  • ck-ok
                    • 2592
                    #624
                    I still dont work
                    you could always try this http://www.digital-kaos.co.uk/forums...-0-1-a-112076/
                    • Cornholio
                      • May 2010
                      • 14
                      #625
                      Ty, ive tried it now.
                      I have tried an dvd-rw and an regular DVD video ( The chronicles of Riddick, maybe it just some dvd's that work? :S)In all menus, its says Invalid DVD,
                      I Updated it then afterwords. And its the same.
                      Could it be that I have that stupid Chip in my Wii? If i know that I have it and no Hack is available right now ill just go and buy a big external hdd. But I want to know that first
                      Do you guys have any info on WHEN they put in those chips? Like a date. So then Ill try figure out when i bought my wii more exactly and see if it has a chip or not.
                      If you guys are sure my Wii probably dont have it, then plz continue helping me with DVD's and that.
                      ty so much for your help
                      • ck-ok
                        • 2592
                        #626
                        check your serial number against this Wii Drive Chip Database d3-2 are the ones that cant be hacked
                        • Cornholio
                          • May 2010
                          • 14
                          #627
                          Here is mine.
                          Wii Drive Chip Database - Serial Number Estimation
                          There is a 100% chance the chipset is GC2-D3-2 (v2) with no drive chip.
                          Poor me Seems its no-hackable.
                          So does this mean I must stick to USB, Extern hardrives untill an hack can be found?
                          But movies can be watched from An HDD yea?
                          EDITED
                          Btw is there a Chip availible for the d3-2 drive?
                          And one last question..
                          Will hackers/modders try to hack this new drive? I think they probably would, because i think they like hacking, and this is a challenge.
                          And it might evan be posted here
                          thx for all your help
                          Now for further questions of People that have troubles with this DVD-r stuff, Check if you have d3-2!!! Thats like the first thing to do!
                          • ck-ok
                            • 2592
                            #628
                            Here is mine.
                            EDITED
                            oh all that work for nothing,but you can still play backup games and movies from a usb stick or hdd, hackers are not working on drives, the wii hackers are all moving to usb/hdd loading,but you can buy a new drive for it but you would be better off spending that money on a good hdd
                            • rev0luci0n
                              • May 2010
                              • 4
                              #629
                              Thanks!
                              I actually went to install an older version of preloader last night, but it threw up an error about ES_DIverify
                              Are there any additional steps after running through the tutorial on page one to patch ES_DIverify?
                              • Timmaa
                                • 88
                                #630
                                This may be a silly question but...
                                I have to start up my Wii and press the 'reset' button to see the priiloader menu. Then I can take an option to boot to system menu. Is it only under these conditions that the priiloader hacks are effective? ie: If I don't force the Wii to first boot priiloader in this way, the DVD may force the Wii to ask for update?
