Wii 4.2E softmod tutorial. Easy to follow guide.
  • ck-ok
    • 2592
    #646
    Originally posted by Timmaa
    Cheers ck-ok, but I'm not sure I put my question across properly. If you install priiloader does that automatically mean it will run in the background when you boot up the Wii or does it only run when you invoke the priiloader menu by pressing 'reset' as the Wii boots up?
    edit: I've just double checked the settings and see that priiloader is set to boot to system menu by default, so I think it's fair to assume that it always boots up when starting the Wii and follows on into the system menu. That would also explain why my NTFS cISO is running on my PAL Wii.
    yes thats right
    • MasterTK
      • May 2010
      • 6
      #647
      I don't know what I'm doing wrong... I downloaded and copies those files on my sd-card, but when I go to the sd-menu, My Wii does not recognize them or load anything?
      • ck-ok
        • 2592
        #648
        you need the homebrew channel installed first if you dont already have it scroll down the first page untill you see download bannerbomb
        • MasterTK
          • May 2010
          • 6
          #649
          Oh, thank you so much! Sorry, if I'm asking too much, but I have one more question. I downloaded bannerbomb and something called hackmii installer from the first page's link. Then booted my Wii and got a menu:
          - Install homebrew channel
          - Install DVDX
          - Bootmii...
          Should I just install that home brew channel there?
          • ck-ok
            • 2592
            #650
            - Install DVDX
            - Bootmii...
            install them all
            • MasterTK
              • May 2010
              • 6
              #651
              Thank you so much. Everything worked perfectly. The only problem is that the game channel shows now this message:
              "in order to use software, you must perform a Wii system update etc."
              Is that normal and what should I do with it?
              • ck-ok
                • 2592
                #652
                have you done the fullmod or just the hbc
                and what game do you have in the drive
                • MasterTK
                  • May 2010
                  • 6
                  #653
                  I just installed everything what were mentioned on the first page.
                  - hbc
                  - dvdx
                  - bootmii
                  Then followed the guide from 1. to 10.
                  I have Wii sports in drive and system menu shows 3.4e.
                  EDIT: I tried with Zelda TP and it worked without update. Can't understand why I have to update with Wii sports.
                  • ck-ok
                    • 2592
                    #654
                    - hbc
                    - dvdx
                    - bootmii
                    christ you have followed a guide for 4.2 when your on 3.4 lucky you didnt brick
                    if your sure your not on 4.2 you had better use this Digital Kaos - Downloads - v4.2 safe firmware updater
                    • MasterTK
                      • May 2010
                      • 6
                      #655
                      I meant 4.3e. Sorry, my mistake!
                      EDIT: It seems that Zelda TP is my only original game I can play now without updating. Mario Galaxy also tells me, that I need to update. >_<
                      • ck-ok
                        • 2592
                        #656
                        if your on 4.2 just let them update they just want to install ios files so they can work
                        • MasterTK
                          • May 2010
                          • 6
                          #657
                          Yes, yes! Can't say how much I want to thank you now!
                          *goes playing*
                          • eamo4648
                            • 6
                            #658
                            Hi Guys
                            i had softmod 4.2e working fine, the wii was updated via a worldcup game and now i have a blank black screen when click on uloader
                            any ideas
                            • ck-ok
                              • 2592
                              #659
                              Originally posted by eamo4648
                              Hi Guys
                              any ideas
                              does any other games work?
                              • Yumraaj
                                • 306
                                #660
                                Hi Guys
                                any ideas
                                Is your copy of World cup 2010 same version as your system?
