Xbox complete guide to flashing, burning games..updated
Donload the burnermax payload tool. It tells mtk based burners to burn the extra space required.
And yes you can as long as everythin checks out in abgx.
Remember ap2.5 active titles I cluding xdg3 games must now have topology data to boot.
If you truncate you lose the last section of tbe iso. This can cahse faults also there has been checks in this space before
Sent from my GT-I9300 using Tapatalk 2sigpic
so bottom line is i must run them through abgx and also burn them on a drive that has burnermax installed ?Donload the burnermax payload tool. It tells mtk based burners to burn the extra space required.
Sent from my GT-I9300 using Tapatalk 2Comment
thanks cunny both the pc and the ihas drive are both now burnermax ready
one last question
is there anyway to rip the image off the discs i already have then run them through agbx then reburn to save downloading all the games?Comment
Cunny mate every single game I have' over 50 titles don't work ' I have re-burnt driver the game and it still doesn't read Think I need to rethink
can you suggestComment
Well its either a weak laser or your backups.
Instal kprobe and test the burn of driver u did
It cant be a weaK laser it read every disc before no problem ' and when i flashed it i even unpluged the laser is it possible i flashed it with the wrong firmware or the flash didnt go correct .Well its either a weak laser or your backups.
http://www.digital-kaos.co.uk/forums...z-read-266619/Comment
Did you not save the logs from jungle flasher? There no harm in trying a reflash.
I'd also still check your backups with kprobe. Its just a process of eliminationsigpic
