Xbox complete guide to flashing, burning games..updated
  • cunny
    • 4915
    #196
    I have emailed you your stock fw. By the looks of things everything went fine on the flash. Drive respond to eject? Does it play games/dvds?
    • NICETOBNICE
      • Nov 2011
      • 551
      #197
      Cunny your the man' I have just plugged it in and put in a original disc and it works perfectly I then signed in' and then it asked me to do an update so just waiting for it to finish really pleased mate . what's the next step pal ?
      • cunny
        • 4915
        #198
        If you want it to play backups you will now load the dummy.bin into source, load LT3.0 for 0251 spoof it and flash drive again. You then should be able to play backups. Unplug the laset power ribbon before you flash though.
        Been a long slog for you mate but a learning curve
        • NICETOBNICE
          • Nov 2011
          • 551
          #199
          Just double checking mate I have downloaded the Latest_iXtreme_and_Stock_Firmware_Pack is this one correct LTPlus-0251-v3.0
          • cunny
            • 4915
            #200
            Looks it to me pal
            Sent from my GT-I9305 using Tapatalk 4
            • NICETOBNICE
              • Nov 2011
              • 551
              #201
              Great mate it works yi***ee. noticed one thing though sometimes half way through the game it says it cannot read the disc they are all verbs and worked perfect before so am I right in saying the laser could do with being tweaked ?
              • cunny
                • 4915
                #202
                Yes it can be pot tweaked. But BEFORE you do. Run your backups through abgx then kprobe. Post results. This will cbeck backups are patched correctly and then the burn is of good quality
                • NICETOBNICE
                  • Nov 2011
                  • 551
                  #203
                  so all the discs I have already have to be checked and possibly burned again?
                  • cunny
                    • 4915
                    #204
                    Depends on few things that. You could also try copying the 1s you want to play to your hdd
                    • NICETOBNICE
                      • Nov 2011
                      • 551
                      #205
                      tell me more about the hard drive cunny i'm liking this what do I have to do can I connect a external drive . my son has a wii that has tons of games on a hdd its great I would love that same thing on the xbox tell me more
                      • cunny
                        • 4915
                        #206
                        Atm you can only copy your game to a hdd and have the game in the tray.
                        A rgh/jtag allows you to overcome this.
                        Also optical disc drive emulators can over come this like xkey. Also team xecuter and c4e are currently working on 1.
                        • NICETOBNICE
                          • Nov 2011
                          • 551
                          #207
                          ok cunny can you talk me through the agbx thing say I have a game that needs to run through agbx what do I do ?
                          • cunny
                            • 4915
                            #208
                            Use these settings here abgx360 v1.0.6 - Quick Guide & Settings You can change the input to either burnt disc or .iso
                            Kprobe guide here http://www.digital-kaos.co.uk/forums...z-read-266619/
                            • NICETOBNICE
                              • Nov 2011
                              • 551
                              #209
                              when you put an game in if it has to be patched through agbx does it burn it to the existing game ?
                              • Partymad09
                                • 76
                                #210
                                can any off the xbox driver be mod to play back please help
