Xbox complete guide to flashing, burning games..updated
  • cunny
    • 4915
    #136
    Delete all files within the firmware folder of jungleflasher.
    Then in latest pack. Browse to post 146 folder. There should be all lt3.0 files for all drives.
    Your looking for 0251 but to be safe its easier to copy all these into the firmware folder in jungleflasher directory and let it auto load it.
    Sent from my GT-I9300 using Tapatalk 2
    • NICETOBNICE
      • Nov 2011
      • 551
      #137
      thanks cunny all done but had to find the 0251 firmware and load on its own
      all i need to do now is put it back together and test will let you no tomorrow
      • NICETOBNICE
        • Nov 2011
        • 551
        #138
        what i would like to know is what does the firmware mean
        for instance ltplus 205 ltplus 206 you would think the 206 is the newest firmware
        can you explain
        • NICETOBNICE
          • Nov 2011
          • 551
          #139
          Hi cunny just hooked the xbox up and inserted a backup game but it wont load it says unreconized disc everything seem to go great not sure what to do now
          • cunny
            • 4915
            #140
            can you explain
            You get different firmwares for different drives/revisions when holes are patched etc. You get CFW for these scenarios
            As regards to your problem. Did you save the Junglefalsher logs
            • blacky1973
              • 304
              #141
              hiya, how can i check if my xbox can be flashed without opening it up?
              • cunny
                • 4915
                #142
                All can be flashed. None can be done without opening the console
                • NICETOBNICE
                  • Nov 2011
                  • 551
                  #143
                  this is the result after flashing the xbox
                  • cunny
                    • 4915
                    #144
                    Can you save it to a text file and copy + paste it in. Hard to read image
                    Cheers
                    • NICETOBNICE
                      • Nov 2011
                      • 551
                      #145
                      ---------------???-???-???------+-++-++-+-v1.0.6-------[http://abgx360.net]----
                      Checking for updates to abgx360.dat...
                      Server file abgx360.dat no newer than local file - not retrieving
                      Layerbreak for this DVD was reported as 2086912 (should have been 2133520)
                      Note: This might still be bootable on LT+ v2.0 or later firmware
                      Checking Game
                      ISO: "Optiarc BD ROM BC-5500S 1.B2 < Dec26,2007> [ATA] (D"
                      Layerbreak: 2086912 (should have been 2133520)
                      Size: 8547991552 bytes (filesize too small!)
                      Warning: This ISO is short 148439040 bytes! Part of the game data is missing!
                      (should have been at least 8696430592 bytes)
                      Files in ISO: 431, Folders in ISO: 25
                      Total bytes used: 6911011001 (79.78%)
                      Game appears to have random padding
                      Checking default.xex
                      Original PE Filename: driverng_master.exe
                      Original PE Timestamp: 2011/07/11 19:51:31
                      Min Kernel Required: v2.0.13146.0
                      Game Name: DRIVER San Francisco
                      No Avatar Awards
                      Achievements: 50 Achievements totaling 1000 Gamerscore
                      XEX CRC = 803C535F
                      XEX Media ID: D664F5CB98F39197BB933A8C-2F510839
                      Region Code: 0xFFFFFFFF
                      Region Free!
                      Checking topology data
                      The first 12 sectors of topology data are blank!
                      Querying the online database to find the appropriate verified data to use...
                      Topology information was downloaded successfully
                      Looking for TOP_XGD3-DID-F87A804E_v1.sha1 in the online verified database
                      Server file TOP_XGD3-DID-F87A804E_v1.sha1 no newer than local file - not re
                      trieving
                      Your topology data doesn't match the file in the database!
                      Attempting to fix the topology data
                      Aborting fix because writing is disabled
                      Checking SS
                      Timestamp of Authoring: 2011/07/18 00:00:00
                      Timestamp of Mastering: 2011/08/11 06:24:51
                      SS Version: 2 (trusted)
                      SS CRC = A82F0FA5 (RawSS = DA1391A0)
                      SS Media ID: D664F5CB98F39197BB933A8C-2F510839 (matches game)
                      SS looks valid
                      Checking DMI
                      Timestamp of Authoring: 2011/07/18 00:00:00 (matches SS)
                      DMI CRC = 478315C3
                      DMI Media ID: D664F5CB98F39197BB933A8C-2F510839 (matches game)
                      DMI looks valid
                      Checking PFI
                      PFI CRC = 26AF4C58
                      PFI matches known data (XGD3)
                      Video partition found
                      ISO size is too small to contain the L1 Video! Video CRC check was aborted
                      Stealth check failed!
                      Press any key to exit . . .
                      • cunny
                        • 4915
                        #146
                        The game wont be bootable as topology data is missing. It has also nkt been burnt with burner max fw.
                        You need a new iso of the game. Run tbrough abgx ensure all passes. Then burn thro burnermax fw or payload.
                        Topology data was made to defeat ap2.5
                        • NICETOBNICE
                          • Nov 2011
                          • 551
                          #147
                          Not sure if this is anybetter
                          • NICETOBNICE
                            • Nov 2011
                            • 551
                            #148
                            thanks for all your help cunny so all my games are scrap is there a way to reburn them ?
                            • haribo
                              • 157
                              #149
                              not them all :whistle:
                              just redownload the img and reburn .
                              dont be forcd into buying more hardware to burn these larger type games. I usually successfully 'truncate' as long as I burn nice and slow like x2
                              list of xdg3 games need reburnt
                              • cunny
                                • 4915
                                #150
                                Have you not tried payload? And nobody forces anyone to do anythi g
