Xbox complete guide to flashing, burning games..updated
  • cunny
    • 4915
    #106
    There is no methid for slim hitachi drives u will have to wait for ltu fw an pcb
    Sent from my GT-I9300 using Tapatalk 2
    • casper1690
      • Feb 2011
      • 213
      #107
      So I can't flash my box then?? How long for guid. It says 2010 on my drive aswel. Just bought it for xmas .
      • cunny
        • 4915
        #108
        Its not out and no release date. You could always rgh it
        • casper1690
          • Feb 2011
          • 213
          #109
          How do I do that mate?? Rgh??
          • cunny
            • 4915
            #110
            It requires soldering and is basically the jailbreak of the 360. Allows homebrew and games to be ran from hdd.
            If you still want live then a dual nand soloution like team xecuter demon will be needed
            • casper1690
              • Feb 2011
              • 213
              #111
              aw wel seems just to tricky. can i buy another dvd drive and do it that way?? dnt need live also. just to get free games
              would any other drive work?? i can get this
              NEW ***8211; Xbox 360 (Slim) Drive UNLOCKED - PHILIPS LITEON (DG-16D4S: 9504/ 0225) ebay
              • cunny
                • 4915
                #112
                Drives aint interchangable like that. You would still need your drive key which you cant get from that drive.
                Rgh would be needed to obtain that or the dgx depends on drive version.
                Options are as stated.
                Rgh or wait for pcb but some soldering will be needed for drive key be it rgh or dgx method
                • casper1690
                  • Feb 2011
                  • 213
                  #113
                  ok will wait manny thanks. p.s are all new slim xbox hitchi drives? mit try get a swap
                  • cunny
                    • 4915
                    #114
                    You will want an older slim. Have a look the d4s are flashable but need unlock or a new pcb. But the hitachi an 5s are not atm
                    • gordi415
                      • Oct 2011
                      • 20
                      #115
                      im new to this Xbox modding scene. i was wondering what modding tool would be better to buy the x360usb pro or the ck3i and probe. can the x360usb do everything the ck3i does and vise versa?
                      • SuperSavingMom
                        • Apr 2013
                        • 15
                        #116
                        ok this is such hitech info,, hope i dont screw up on this...hihihihi
                        • SuperSavingMom
                          • Apr 2013
                          • 15
                          #117
                          ooopppss i pulled to hard on the cable ,, trying to fix it.. ok good to go again the white thingie came lose,, but no damage...
                          • NICETOBNICE
                            • Nov 2011
                            • 551
                            #118
                            My son has had a xbox360 for some time its been flashed with some software that i'm not aware of all i no is it plays all the backup games 'my dilemma is i would like to update the dashboard.
                            With all that in mind i think i would like to be able to flash the xbox my self i'm pretty hands on and good with a soldering iron i also work for a electronic company so would be able to make my own leads if i had to
                            is there a simple way it can be done ?
                            • cunny
                              • 4915
                              #119
                              It all depends on the drive. Do you have a copy of the drive key? Liteon drives in Phat xbox are the only 1s that need extra hardware (probe v3) all the others can be done via compatable chipset and a way to power the drive easily
                              • NICETOBNICE
                                • Nov 2011
                                • 551
                                #120
                                Thanks cunny Whats a drive Key? also just took the front panel off and i can see 2 yellow wire is this a liteon phillips drive ?
