The PMT and Scorpian get the keys from the drives so no, i dont think you would need them, but as you said, you keep the keys and that's a good practise
Xbox complete guide to flashing, burning games..updated
hav u used any of them yet m8, if so how did things go with them, and when you say in your post
"The PMT and Scorpian get the keys from the drives"
do you mean they can pick up the original key from your box even though the drive has been flashedComment
I assume so, as LT is supposed to be as close as C4E can get it, then I would imagine that you would get it if its been flashed before, regardless of FW
I am awaiting delivery of a Probe V3 and a X360 but when they arrive, i will be trying them out
This is a step by step guide for the 9 series with the X360 done by Ubergeek over on TX so all credit to him
Code:http://team-xecuter.com/forums/showthread.php?t=60930
Hi cunny, need ur pro assistance sir...i'm having problem playing the latest backup games such as the need for speed hot pursuit having stuck at logo xbox360...the only game i can play so far is modern warfare 2 with kind of bootdisc stated ver 1.6..etc..etc...i have check thru ur guide that my xbox is the phat with kind of yellow cable when i verify it and i assume that it is confirm DG-16D2S..How do i upgrade the firmware to the latest version so that it no more longer using a bootdisc to play or whichever is easy ...no idea at all since this xbox set was pass down to me by my fren which he bought from the shop....Comment
You will need to pull key off drive. Update dashboard and flash to 1.9 if you want to use live.
You could just reflash drive to lt1.1. Again follow the tuts here on team xecuter and the jungleflasher guide.
I have done a few boxes this week and updated dash and firmware this is so they won't get flashed again when dashboard 146 comes onto games and flashes their drives.
If you can't do the upgrade then I am sure someone local to you.
The game issue sounds like ap25 checks
Sent from my GT-I9000 using Tapatalksigpic
thnx cunny i will do it by myself..any assist can i get direct from u if not sure....this case i need to purchase the probe as u say right from team axecuter....thnx againComment
Hi
Quick (noobie) question..
was looking to get a premodded slim and someone has one available which is has the new unlock PCB+ installed.
Is this the latest one to get?
I have read that once you update the firmware, it is locked so it cannot be overwritten unless you unlock it?
Thanks for your help.Comment
