Epson SX125 waste ink counter reset
  • Canker_Canison
    • May 2010
    • 3905
    #151
    Originally posted by topjazz
    Hello,
    I just bought 1 original epson cartridge (yellow), and replaced it.
    After replacing it, all cartridges are disabled.
    I must say in the past i used also compatible cartridges.
    I've tried everything (power off for a while, desconect from pc, etc...), nothing helps...
    I hope the epson sx125 waste ink counter tool will help...
    Greetings,
    topjazz
    It's a duff cartridge, go and get it changed.
    THIS SOFTWARE WILL NOT FIX CARTRIDGE PROBLEMS
    Canker
    [COLOR=Green]
    • topjazz
      • Nov 2012
      #152
      Hallo,
      thanks for the answer, Canker_Canison !
      the software (epson sx125 waste ink counter tool) did not work, because all cartridges must be active.
      the yellow cartridge have i replaced with a compatible one, and it's work again
      after repacing the yellow cartridge the software (epson sx125 waste ink counter tool) works, but i have not enough knowledge to work with it (it's english, maybe there's something in dutch ?)
      Greetings,
      topjazz
      • geniusjames
        • Nov 2012
        Do it works for stylus sx235w?
        • mpakolas
          • Nov 2012
          Hello people! I have an Epson sx125 and i tried to reset it through an application called ssc service utility. the problem is that this application is not compatible with my model. I am running win7. Do you have an idea in order to reset my printer?
          • Unk
            • Nov 2012
            Thanks for the tool.
            As told before, it won't work if there is already one cartdridge with problems/not recognized.
            I guess I'll get a black one original and then the procedure for using compatible cartdridges should work with no problems at all.
            Also, I'd probably apply for a CISS system avoiding wasting time and money with expensive (ratio ink/price) cartdridges.
            • nick162
              • Dec 2012
              sx235
              hi does this sofware reset the sx235 printer
              • AminmB
                • Dec 2012
                Thx dude!
                Do you have reseter for px660?
                • Petre
                  • Dec 2012
                  Do I need code for reseting the counters like wic reseter?
                  do I need a code to reset the printer ink counter?
                  • stawa
                    • Dec 2012
                    i did try to take out all ink (non original)cartridges for few minutes,disconnect printer from comp and mains,and install them again.didn't work for me.now will try soft posted here
                    • rumun13666
                      • Dec 2012
                      refill
                      will it work after refilling cartridge with needle by myself?
                      • yatata
                        • Dec 2012
                        Thanks. I'm going to try it.
                        EDIT: I have tried it but my problem has not been solved. My problem here is that I have two new cartridges (compatible ones with auto-reseteable chip) and the printer says it doesn't recognize them (cyan and magenta). Do you know what could be happening here? I have tried different cartridges but the result is the same.
                        • dubeu
                          • Dec 2012
                          I still dont understand why Epson is doing this. It is so unfair that I have to buy new blue color. I dont use blue but is is draining. I only use black..
                          • Canker_Canison
                            • May 2010
                            • 3905
                            #163
                            The cyan & magenta chips are faulty & need replacing.
                            Canker
                            [COLOR=Green]
                            • fireman1904
                              • Dec 2012
                              why do we need to reset the ink, they said that may pad ink end of service :t
                              • emy1982
                                • Dec 2012
                                help me
                                help me, my epson sx130 don't see black color original
