dell latitude d630 admin password ??
  • smoggy
    • Apr 2009
    • 12772
    #1171
    Originally posted by Muckifanten
    This password is unfortunately not correct. There is no Latitude laptop. It is a Optiplex GX 520 with the service tag number 82N3C2J Is it because it is not a notebook?
    I'm not sure if they work on desktops
    is there any more numbers after 82N3C2J like -595B
    and have you typed the tag and serial in the correct case as they are case sensitive, also they are for a qwerty type keyboard
    • arissusanto
      • Nov 2011
      • 4
      #1172
      Good afternoon masters m so sorry for request help again. Sorry if my english was so bad
      i have try the password that you gave yesterday and this is work very good. But, after i use that password, there is other password request on my laptop screen. The notification is like this : "Hard-disk #XE208A10913-595B, the system primary HDD, is protected by a password authentication system. You cannot access data on this hard drive without the correct password". I try to use same password that you gave, but not work. Please masters, help me again.
      What am i going to do?
      Thank you so much
      • Muckifanten
        • Nov 2011
        • 6
        #1173
        The service tag number is correct, 82N3C2J, all letters written large. Without attachments-595B and the Express Service Code: 17573977819. What is a qwerty keyboard strokes? In Germany, bought keyboard?
        • smoggy
          • Apr 2009
          • 12772
          #1174
          QWERTY keyboard is when the first five keys of top row are QWERTY
          it also needs to be set as English language
          • smoggy
            • Apr 2009
            • 12772
            #1175
            Thank you so much
            I've summised 4th and 8th are zero's
            password 256jv02b (6th is a zero)
            • mcrkid301
              • Nov 2011
              #1176
              latitude d630
              Hey my brother handed me down this computer from his old office but it is still locked, i would really appreciate it if you could help me out, the service tag is: 52LRXG1-595B
              • arissusanto
                • Nov 2011
                • 4
                #1177
                Thanks master, it is work! Now i reinstall my laptop. Thanks 4 all of helps.
                Regard..
                • smoggy
                  • Apr 2009
                  • 12772
                  #1178
                  first post should be here Introduce Yourself
                  say hello and join the community
                  in the meantime password ubw26ye4
                  • v306647
                    • Nov 2011
                    #1179
                    Service Tag
                    I believe all Dell Service Tag numbers are 7 digits and all end in 1. I tried looking up the tag you gave, substiuting a 1 on the end instead of J, and it does not exist. Look for a white bar coded label on the back of the machine, for the Service Tag.
                    For Dell GX520,s there is a jumper to disable passwords on the machine. You can look here Documentation under System Board Components. PSWD JUMPER - remove it.
                    • notisz
                      • Oct 2011
                      • 4
                      #1180
                      my friend i need another one 7VL0J3J-595B
                      • Muckifanten
                        • Nov 2011
                        • 6
                        #1181
                        Thanks, I've removed the jumper, I'm fine.
                        • mcrkid301
                          • Nov 2011
                          #1182
                          i just realised that it was a "Z" not a "2"
                          the actual service tag is: 5ZLRXG1-595B
                          • scnuckellein
                            • Nov 2011
                            • 9
                            #1183
                            Hi
                            in the meantime password m03rd3js (2nd is a zero)
                            I unfortunately made a mistake in the service tag number, the last number was wrong. Apology ... the correct service tag number: 5Y4CW2J-595B. I'm sorry.
                            • lmsvvavr
                              • Jul 2010
                              • 569
                              #1184
                              Hi
                              Your paswword should be: zgqy9feq
                              Hit Thanks if helped you!
                              Thank You for the help!
                              "A Wise Man can see more from the bottom of a well than a Fool can see from the top of a mountain."
                              http://www.youtube.com/c/LMAutoRepairs
                              • lmsvvavr
                                • Jul 2010
                                • 569
                                #1185
                                Hi
                                Your password should be: jtwfkbpq
