Huawei E5830, E5832 & E5838 Free Unlock
  • Jim.Mahoney
    • Feb 2010
    • 4249
    #166
    Originally posted by matthew27
    hi
    pls unlock thankks.
    ABC.TXT
    e5830
    Sorry, file link takes me to a blocked site as it contains malicious code!
    Files posted on the forum ONLY will be examined for codes!!
    • matthew27
      • Mar 2012
      • 47
      #167
      thanks.
      pls try this.
      ABC.TXT - 4shared.com - document sharing - download
      • matthew27
        • Mar 2012
        • 47
        #168
        hi
        pls try at my attachment
        tia.
        • matthew27
          • Mar 2012
          • 47
          #169
          pls check maybe this is is correct.
          thanks.
          • Jim.Mahoney
            • Feb 2010
            • 4249
            #170
            thanks.
            Neither are correct!
            File should be 700 to 760K before being compressed!
            Follow the steps again with SIM removed!
            • pepol
              • Mar 2012
              #171
              i can?t make it works with linux wine
              • pepol
                • Mar 2012
                #172
                yea! , it works with windows :S , but it woks , just the first code from the extract tool list!!! and it's done
                • Jim.Mahoney
                  • Feb 2010
                  • 4249
                  #173
                  Good news! It's not always the first code! It's position depends on model and firmware version...
                  • ladyboy
                    • Mar 2012
                    • 5
                    #174
                    can a Globe Philippines Huawei E5832-S be unlocked? Globe sucks and I have enough of this sucking thing
                    • Jim.Mahoney
                      • Feb 2010
                      • 4249
                      #175
                      Why not try it?
                      • ladyboy
                        • Mar 2012
                        • 5
                        #176
                        Originally posted by Jim.Mahoney
                        Why not try it?
                        i did. but after hitting the "let's go" button, error pop up says: "phone does not respond.maybe another software is blocking the port."
                        it happens all the time. i tried it like a hundred times. same pop up. i tried looking into what port and all are not using the com where huawei is but still same pop up error.
                        • ladyboy
                          • Mar 2012
                          • 5
                          #177
                          i am now able to connect but problem now is i can't seem to know what of these is the password. i have used text extract.
                          • ladyboy
                            • Mar 2012
                            • 5
                            #178
                            geez. i'm at the final stage but whenever i unrar the unlock card rar file it says no archive! can you pls. just post the software?
                            • Jim.Mahoney
                              • Feb 2010
                              • 4249
                              #179
                              Post your EFS file here it should be between 700 and 760K before your RAR or ZIP the file...
                              • ladyboy
                                • Mar 2012
                                • 5
                                #180
                                thank you. here is the rar file. it is named lock.rar.
