Huawei E5830, E5832 & E5838 Free Unlock
  • redddevil
    • May 2012
    • 17
    #256
    Are you saying that I need to re-flash and the fact that I can now do web access doesn't necessarily mean that the flash worked?
    Will DC unlocker still report old firmware version or should it report it as 716.11.17 etc?
    Won't be able to try this until tomorrow now I'm afraid but will report back.
    • Jim.Mahoney
      • Feb 2010
      • 4249
      #257
      The firmware should be reported as the new 716 version... When flashing the modem will make this obvious with LED blinking at least!!
      If you have not gone into flash mode, you may have only partly reset the modem!!
      • redddevil
        • May 2012
        • 17
        #258
        OK will re-do in flash mode then reset and retry the EFS read.
        TFYH
        • redddevil
          • May 2012
          • 17
          #259
          This looks much more promising as EFS is now 754kb!
          I'm guessing 23064162 ?
          • redddevil
            • May 2012
            • 17
            #260
            Ok - I tried it and it unlocked successfully so thanks to Jim and also to MKAlex who did actually identify this as the unlock code from the 'non-standard' EFS dump.
            At least having gone the 'long way' round I now have updated firmware as well!
            One thing you guys might be able to answer is why, after the system reset, the modem reverted to an SSID of 'mikeandkatie' when I'd previously changed it from that. I can't believe that's a system default.
            Either way many thanks for your great support.
            • Jim.Mahoney
              • Feb 2010
              • 4249
              #261
              Very odd that 23064162 worked as it should be prefixed 01 01 in hex. I saw it in the original file but I'm loathed to get people to try codes as some devices have as few a three attempts before the games up!
              I rather think that you had 'crippled' firmware that is so often used by the networks nowadays! I'm guessing that was causing most of the oddities.
              It could be that settings set via the USB (Mobile Partner) interface are stored in NVR but anything set via the http interface is not...
              • MKAlex
                • Feb 2010
                • 165
                #262
                Originally posted by MKAlex
                Unlock Code: 23064162
                you welcome
                Originally posted by Jim.Mahoney
                Not convinced as the code is in the wrong area!
                I was 100% sure that the code is valid
                I unlocked a few modems with the same efs
                • Madmancluj
                  • May 2012
                  #263
                  Found the nlock code for my Huawei 5832s
                  Thank you guys! I have downloaded EFS info and found my unlock code as the first string of 8 numbers.
                  My Huawei 5832s is now unlocked.
                  Where can I find a decent firmware? Tried with Netvigator E5832sUpdate_956.11.17.05.309 but cannot edit APN from the web interface and didn't tried several Mobile Partner to connect but no success...
                  Thanks again!
                  • redddevil
                    • May 2012
                    • 17
                    #264
                    the one Jim pointed me to in post 252 allowed me to just drop in a T-Mobile chip and connect straight away...
                    • Jim.Mahoney
                      • Feb 2010
                      • 4249
                      #265
                      Thanks again!
                      Try upgrading the dashboard also!
                      • Madmancluj
                        • May 2012
                        #266
                        Thanks reddevil!
                        Did you try E5830 firmware on E5832s? Is it working?
                        • Madmancluj
                          • May 2012
                          #267
                          Thanks Jim!
                          I have tried with dashboard from dc-files but it didn't work, think there are some issues between Win 7 and Huawei drivers.
                          • Jim.Mahoney
                            • Feb 2010
                            • 4249
                            #268
                            Thanks reddevil!
                            If you flash E5830 firmware to a E5832s you will kill it!
                            • eraserheads4
                              • May 2012
                              how to download qmat for free?
                              • Jim.Mahoney
                                • Feb 2010
                                • 4249
                                #270
                                Follow the link on page one of this thread!
