cloud ibox 2
  • eddhutch
    • Sep 2013
    • 13
    #616
    Thought that m8. Could I take one from a mini solo or can you buy them local. Cheers mate
    Sent from my GT-I9300 using Tapatalk
    • shock2kuk
      • Jun 2009
      • 10
      #617
      Just solder a small peice of wire from the centre pin of the connector to the solder point on the board. you could use something like the centre conductor out of a peice of coax or something similar
      • eddhutch
        • Sep 2013
        • 13
        #618
        Im a bit of a newbie. Where's the centre pin of connector and conducter?. And use copper wire ie coax. Cheers m8
        • bighun
          • Nov 2010
          • 151
          #619
          get a small bit of coax cable strip the brown outside of then the white inner that will leave you the copper solder it to the the middle wire of the satellite connector then solder it to the point on the main board where the wire should go
          • eddhutch
            • Sep 2013
            • 13
            #620
            Sounds good m8. Thanks a lot. Al keep you updated
            • zocon
              • Nov 2013
              Hello I have had many problems with the seller from aliexpress susana lui Store called dvb shenzheb Electronics Factory. You do not buy the Cloud ibox2 in that store, they are scammers.
              Enviado desde mi ZP980 mediante Tapatalk
              • redbellied
                • Feb 2010
                • 6
                #622
                Can some one recommend a good site to buy the ibox2 from?
                Cheers
                • tkm18
                  • Aug 2009
                  • 158
                  #623
                  Typical, ordered another ibox2 and gotbsent the snyder that keeps freezing, first had no switch etc.
                  Second one looks better, but crashed after my first attempt and dling the epg on vix, openpli lasts a bit longer, but not greatly.
                  • lombard
                    • Aug 2008
                    • 793
                    #624
                    Hi, i done the fix soldered the resistor and been working full 1 day now before didn't last 30min-1hr, using latest vix 3.0 build , epg , picons saved in flash memory still have 90mb free, not had no issues and everything seems to work fine, although with same setup on vu solo , the solo does noticeably run much smoother and faster, channel hopping etc, downloading epgm can really notice difference
                    Thanks for the fix !
                    • eddhutch
                      • Sep 2013
                      • 13
                      #625
                      Thanks very much m8. You where bang on. Now tuner running perfect. Thanks m8
                      • jenseneverest12
                        • Nov 2013
                        • 22
                        #626
                        All of the 8 repairs i have done are still working 4 days later, but i have had boxes fail that are a month old so how long they last is another story.......
                        I agree the solo clone is a better box overall, that being said the biggest issue with cloud2 are the images, like the blurr on the epg. For me the openATV is the best of them.
                        • MyB5
                          • 49
                          #627
                          Cheers
                          Double that....
                          Vu+ Duo-BH 2.0.9,1
                          CloudIbox II+
                          DM600PVR & DM500
                          Skybox F5 & F5s
                          Oscam 9533 & CCcam 2.2.1
                          0.8/ 4.8/ 7.0/ 13.0/ 16.0/ 19.2/ 23,5/ 28,2
                          Scandinavian
                          • lombard
                            • Aug 2008
                            • 793
                            #628
                            Hi, replaced the resistor on 2 boxes, tested for few days now seems fine, had to get very small soldering iron and magnifier glass as its very small
                            • gix222
                              • Sep 2011
                              #629
                              you can always use small wire, the smaller it is the less OME it gives, i put 0,2 ome wire 5cm and it works very well.
                              Ps. tryed all images, ATV open gives me best picture and stabilty.
                              • blue boy
                                • 100
                                #630
                                Hi, Can anyone recommend a supplier of this box that is sending them with the replacement fixed resistor ? I want to buy 3 of these for the family but don't want to have the hassle of having to fix resistors, I bought one of the first batch from Airsat and I have had no problems yet, I won't be buying any more from them because they don't take Paypal any longer. They also sent it with no card reader.
                                Cheers
