cloud ibox 2
  • weonlyadtenmen
    • Nov 2012
    • 6
    #631
    hi,been reading thread with interest,i too would like to know of a recommended supplier with the new fix and also which one is the best i.e some say 600mhz cpu and some 501mhz,there seems to be a few variations,so which is the best and most stable,cheers!!
    • lombard
      • Aug 2008
      • 793
      #632
      as long the resistor been replaced or is better one should be fine, also they all are 501mhz and if advertised as 600mhz its incorrect, strange that i find the vu solo with 333mhz faster then this
      • preditor
        • Nov 2011
        • 82
        #633
        Is anyone's Ts Media movies working? Mine seems to be down
        using openpli.
        Also can someone post a Vix image (latest) with everything installed please?
        Discussions about cardsharing are not allowed...
        Discussions about hacking or modifying cable company equipment will be removed.
        • andyd123
          • 61
          #634
          using openpli.
          I'm watching on TSmedia right now so definetly working. Try different sources in TSmedia
          I'm using Open PLI with TS Media 4.8
          • bighun
            • Nov 2010
            • 151
            #635
            i am still using my cloud ibox2 which is one of the first batch from air digital it is on 24/7 and has never failed me
            • preditor
              • Nov 2011
              • 82
              #636
              I'm using the same..
              When I click on something it says "links down".
              What are you watching Bytheway, just for a test ?
              • andyd123
                • 61
                #637
                I've been watching Breaking Bad but I've just tried a movie in movie25 and works as normal. You need to try different sources if one is off try another you will find what your looking for.
                • preditor
                  • Nov 2011
                  • 82
                  #638
                  Yh
                  thats fine it works now thanks.
                  Also is their a way to forward and rewind the movies?
                  • weonlyadtenmen
                    • Nov 2012
                    • 6
                    #639
                    thanks for reply but can you or anyone else recommend a good trustworthy supplier??
                    • jwalshy97
                      • Dec 2013
                      I have recently purchased the cloud ibox 2 but im not the best with setting it up with what I want, id like to be able to have cccam set up and have a working ts media plugin and would like to know how to set these up simply so I can enjoy this box. Thanks.
                      • andyd123
                        • 61
                        #641
                        Yh
                        To fast forward and rewind use the numbers on your remote.
                        The numbers on left rewind ( 1, 4, 7) and numbers on right fast forward ( 3, 6, 9 )
                        • GuJack20
                          • 4
                          #642
                          Please i to am in search for a trustworthy seller. Airsat is no longer accepting paypal, so please post here or by PM any information you may have
                          Thanks guys
                          • kkkklaur
                            • Nov 2013
                            • 18
                            #643
                            1. Yojia aliexpress
                            2 L&W aliexpress
                            Pay direct with visa card.
                            • bighun
                              • Nov 2010
                              • 151
                              #644
                              i have bought from yojia before they are a good seller
                              • preditor
                                • Nov 2011
                                • 82
                                #645
                                Can someone plz post vix image with everything installed?
                                Would help a lot
