cloud ibox 2
  • spzjulien
    • Nov 2013
    • 15
    #646
    got trouble with my cloud ibox 2
    i cant connect anymore via ftp
    Commande : USER root
    R?ponse : 331 Please specify the password.
    Commande : PASS ******
    R?ponse : 500 OOPS: priv_sock_get_result
    anyone know what is "priv_sock_get_result" ??
    • spzjulien
      • Nov 2013
      • 15
      #647
      problem solved just re-flashed openpli 4
      • eddhutch
        • Sep 2013
        • 13
        #648
        Originally posted by GuJack20
        Please i to am in search for a trustworthy seller. Airsat is no longer accepting paypal, so please post here or by PM any information you may have
        Thanks guys
        PM me for good supplier good coms.
        Thanks guys
        Sent from my GT-I9300 using Tapatalk
        • mack441
          • Sep 2009
          • 32
          #649
          ive been buying these boxes cloud ibox2hd from uk for ?85gbpounds had 1 play up took it back and he replaced it with another one he gives 1 year warranty if you want his details pm me ive bought about 30 of them
          • redondo5
            • 277
            #650
            so what's the verdict on these... briefly looking at the last ferw pages... people seem to be having issues that require soldering etc for these cloud ibox's...
            would i be right in assuming it's best to avoid this clone for now?
            • ajax2061
              • Nov 2012
              • 395
              #651
              Well this box is my first E2 machine after having had a F3, found it easy to setup a lot more powerful and very very reliable, I think it was mainly the first batch that seamed to have problems as personaly I find it too be a great box and the only trouble I get is from trying to do network streaming of films from pc to the box which I gave up on and use my appletv instead.
              Picture is good box is on for about 8-12 hours a day doesn't seam to give any problems. would give it a 8 out 10 would be more if I could watch films via the pc but think tis box don't have the grunt for it
              • mdt
                • 3034
                #652
                for what you save and the countless issue,s why not get a tried and tested vu+solo v3.2, stick B.H. 1.7.2 on it and install your cams/plug-ins. job done for ?80,regards mdt
                • redondo5
                  • 277
                  #653
                  Yep, I would agree. I have a solo 2 as my main receiver. Just looking to tinker with a new box for a while as I have a bit of time on my hands at the moment. I did originally have the cloud ibox 1 but that had overheating issues... I want a linux receiver so was just considering it... i would want to try different images and plugins etc... mainly software side... last thing i would want is a box that needs opening and replacing parts.
                  Would you say solo v3.2 is one of the most reliable and stable clones on the market at the moment?
                  • gix222
                    • Sep 2011
                    #654
                    remote is horrible, can we use dreambox remote, or what is the code for universal remotes to work with this, clicking noise un wheel is just horrible!
                    • eddhutch
                      • Sep 2013
                      • 13
                      #655
                      Could you PM me info please if you dont mind.
                      Cheers
                      • ajax2061
                        • Nov 2012
                        • 395
                        #656
                        yeah remote is very clicky was wondering what/if the max digital remote would work
                        • redondo5
                          • 277
                          #657
                          logitech harmony remotes are a good choice... and if using on one of the cheaper clone receivers, where the IR sensor has a very narrow range... then a good idea to couple it with a USB IR extender (cost about ?3 on auction site) - the benefit of using one of those extenders is useful even if you have direct site, because the eye on the extender sensor behaves a lot like an original VU+ sensor where you can basically point remote away from the sensor/receiver and it will still pick up your remote input.
                          • lombard
                            • Aug 2008
                            • 793
                            #658
                            from all the clones this remote is the worst, button layout aint even same as xp1000 so not great to use and the clicks pressing the middle, and range crap, vu clone remotes never had this issue
                            • weonlyadtenmen
                              • Nov 2012
                              • 6
                              #659
                              where can i purchase one of these for ?80,also i only have experience of openbox type receivers,which are the easiest to set up an where would i find tutorials,all input welcome,thanks!!
                              • yellowking
                                • Feb 2010
                                • 18
                                #660
                                I have an X Solo Mini on test runs all VU Solo images without issue it's cheaper to buy than the iCloud2 and on looking inside and the feel outside I would say it's a better build.
                                It works as well as the iCloud so I think it's going to be a better buy. Once I have a backup image I like I'll be ordering more :-)
