SGSH Bouquet 500C/800HD/800SE
This topic is closed.
  • uu161
    • May 2012
    • 372
    #691
    Originally posted by celestialz
    I'm using a Black Box 500 running OpenPLI software. everything installs perfectly but I'm only getting FTA channels. When I switch to a SH cable channel it's black, but the program info is displayed at the bottom.
    anyone can help, i very new to this...
    didn't read need backup some file before flashing?
    to understand more should read this guide
    if you like the post use the Like button located bottom right corner of each post
    if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
    • celestialz
      • Aug 2013
      #692
      http://www.digital-kaos.co.uk/forums...-first-361627/
      hi uu161,
      i didnt know this forum till my DM500 get stuck up... so i google and get to know this forum... very sad it cannot work now, so hoping anyone that can help me to get this work...
      • Arraysys
        • 173
        #693
        Originally posted by avo24
        Yep..dm800c also name as dm800hd pvr. Dm800se is better then dm800c
        Are you talking about the Clone Dream Multimedia DM800HD PVR Second Edition which have 400MHz processor and a color LED panel in front?
        Technical Specs:
        • RedRidingHood
          • Apr 2013
          • 29
          #694
          anyone can tell me a reliable place to get this, need to find 1 w ready-stock.
          dont want clones
          • avo24
            • Feb 2010
            • 28
            #695
            Technical Specs:
            http://cdn.billiger.com/dynimg/QvKWu...he-Details.pdf
            Yeap that the new dm800 model ... nowaday can't find a original dm800. N3 is coming so no point invest a new box ; ( ..
            • Arraysys
              • 173
              #696
              dont want clones
              Don't want clone then buy from here http://www.dream-multimedia-tv.de/en/products
              Direct from Germany. Cheers.
              • celestialz
                • Aug 2013
                #697
                where to get clone?
                • AVGAL
                  • Jul 2011
                  • 64
                  #698
                  Clones are all from aliexpress or alibaba online stores. Google to search
                  • clitang
                    • Aug 2013
                    • 4
                    #699
                    Don't want clone then buy from here Dreambox | dream-multimedia-tv.de
                    How much does it cost?
                    What tuner is suitable for Singapore?
                    After that what is necessary to make it watchable?
                    Thank you.
                    • pirsquared8
                      • Feb 2013
                      • 114
                      #700
                      Thank you.
                      Did you go to the various websites as advised in the past 8 posts?
                      All answers are in there if you take the time to read them.
                      • planet
                        • Jan 2012
                        • 9
                        #701
                        Originally posted by Zelphon
                        For those who are able to view the channels, can tell me what is the SNR ratio??
                        I am getting about SNR 74% even after cleaning the contacts and also tried 135500 to 136000 MHz in steps on 100 MHz increments.
                        Guess I need an amplifier?
                        My SNR is 78% for BPL. Especially Fox sport news is 99% and rest of the channels is 93%. I am quite lucky.
                        • pirsquared8
                          • Feb 2013
                          • 114
                          #702
                          As for me, the bee pee Elle magazine SNR is hovering around 72-74% with AGC @ 41%.
                          Not using any CATV signal amplifier.
                          Looks stable enough for me although has 0.3 sec pauses / pixelation once every 10-15 mins. can live with it.
                          Beggars can"t be choosers. Just contented with what i have compared to past few years of nothingness :-)
                          • jnashville
                            • Apr 2012
                            • 70
                            #703
                            Where to see signal rate of the channels? I always see all of my channels at 34-36 db. Is that the signal rate? I see 34-36 but all my channels perfectly clear and smooth.
                            • pirsquared8
                              • Feb 2013
                              • 114
                              #704
                              the no. u quoted are measured in dB (decibels) while SNR (Signal to Noise Ratio) is measured in %
                              In my OpenPLi image by master y..125 there is a setting on Menu -> Setup -> System -> User Interface -> Show SNR percentage instead of dB values ...... is set to "NO"
                              from my set 37.6 dB (channel U) correspond to 89%
                              so for yr 34-36 dB could correspond to 80% roughly ??? just guessing
                              Update: got the formula for converting SNR figures from % to dB. Just multiply by a factor of 2.35
                              so for member jnashville's case of 34-36db it translate to (34db x 2.35) 80% to (36dB x 2.35) 84%
                              my analysis is it depends on the "luck of the draw" what signal level u get....
                              • ahhoe
                                • Oct 2011
                                • 13
                                #705
                                I have a DM800HD-C. Trying to update my channels to watch Bee.Pii.LL
                                Downloaded E2SG-Bouquet-082013
                                Dreambox set : Pluck in Lan cable. Hold power button + pluck in power adapter.... get ip 192.168.0.108
                                Dreamboxedit : Confirmed 192.168.0.108 is set. Username (root), password (dreambox), selected enigma2, http port 80, ftp port 21, SAVE!
                                Clicked FTP button --> confirm directory point to right folder, ip address correct, click "Send files to dreambox", I get this message "Connecting to 192.168.0.108.
                                Could not connect to Dreambox. Check IP Address, network settings and status of Dreambox."
                                Any1 know what went wrong?
