SGSH Bouquet 500C/800HD/800SE
This topic is closed.
  • Zelphon
    • Jul 2011
    • 10
    #631
    Originally posted by ypvs125
    U can try use the set 1 bouquet if it is jerky on yr box. The set 1 ch226-ch228 is set at 135000mhz whereas this one is at 135500mhz.
    Master,
    Which is Set 1?
    SGSH Bouquet 14082013 E2 800 & 800SE [With On-Demand Channels]
    or
    E2 Bouquet 16AUG13
    • jnashville
      • Apr 2012
      • 70
      #632
      Originally posted by Zelphon
      All channels except 232 and 233 is watchable..
      Seems like DM800 HD cannot view B.P.L.
      Stop giving wrong info to ppl leh..only u got this problem. I can see all the channels.
      • j4sp3r
        • Dec 2012
        • 16
        #633
        its watchable... u should try putting ur box in different rooms.. mine works only in living room becos the signal is the strongest... in my own room only 232 and 233...
        • shingo86
          • 17
          #634
          Will editing cable.xml n re upload to box work? I can't find the file u uploaded previous time. Media fire say file is deleted.
          Sent from my GT-I9100 using Tapatalk 2
          • Zelphon
            • Jul 2011
            • 10
            #635
            My bad... Sorry
            • ypvs125
              • Dec 2010
              • 506
              #636
              It does not work that way. If u can try the set 1 than i can see the comparison.
              • Arraysys
                • 173
                #637
                For those still cannot watch, you may try below mentioned.
                1st. Remove splitter if any and connect direct from the wall point to the box. The wall point preferred to be the original built point in your house not those type that renovation contractor lay to bedroom.
                2nd. You need to use a good quality signal cable. A good quality cable come with 75ohm and support bandwidth between 45-862MHz.
                (A two meter long cable only cost around $7 in SLT)
                3rd. You may want to try a signal amplifier booster to stabilize the incoming signal before you to the box. Get those signal amplifier booster that need AC power.
                (A signal amplifier booster only cost $15 in SLT)
                If all above mentioned have been done and still cannot watch. That's mean your box is unstable with the broadcast signal. Likely the tuner in the box is having problem. Hope these help you guys. Cheers.
                • uu161
                  • May 2012
                  • 372
                  #638
                  if those buying the signal amplifier buy a better one which much cleaner signals.
                  if you like the post use the Like button located bottom right corner of each post
                  if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
                  • jatrophaseed
                    • 589
                    #639
                    5 matches at 10pm, dont know which to watch.
                    Hahaha.... yes I m flaming envy.
                    We enjoy bcos we started preparing since 27th July ma.... so we deserve the fruits.
                    Sorry Master UU161, I hv only 2 TVs, 1 SD and 1 HD.
                    I manged to feed 4 input to my CCTV and view split screen 1:4, so asa a goal is about to score, I switch to that a/v.
                    Good idea !!! ( with 4boxes ofcos) now I short of 1 more box liao.
                    Aiyaa... after I fixed up everything, Multiview had the same ler....
                    • uu161
                      • May 2012
                      • 372
                      #640
                      watch 5 side by side lor
                      ya yo where got
                      turn on 5 laptop side by side streaming to it can right?
                      duno who show me some box pics hor
                      • puptoon
                        • Aug 2013
                        • 22
                        #641
                        Please allow me to add one more point which is NOT recommend. If u are living in flat, outside the corridor somewhere there is a big white box. All the cables connection which is route to each flat main wall point is inside. If u have seen what's inside the box u will know what I mean. Sometimes u just need to tighten the connection. If I remember correctly each cable that route to your wall point is connected with an amplifed spiltter.
                        But then again chances are the big box is lockup..haha. Take a look outside ur flat , sometimes the box is not locked up. I have seen a few boxes that are not lockup. But again please please do it when everybody is asleep..haha
                        Sent from my Nexus 7 using Tapatalk HD
                        • puptoon
                          • Aug 2013
                          • 22
                          #642
                          The best part is the multiview channel can only show 4 channel:sly:
                          • avo24
                            • Feb 2010
                            • 28
                            #643
                            Any guys here try before the cable tv amplifier (booster) . Is the product good? I can't watch any soccer channel signal show 30.6db only.. could I buy the booster to boost my signal ?? Have fun watching soccer
                            • micromouse
                              • 162
                              #644
                              Hahahaha.. You Have Been Hacked!!!
                              • shingo86
                                • 17
                                #645
                                Halo all master n expert, i tried 135500 n 136000 both jerky. Now only left 135000 to try rite?
