SGSH Bouquet 500C/800HD/800SE
This topic is closed.
  • ncheewee
    • Jun 2013
    I don't have much to contribute except for sharing some earlier setup experience, but really like to say a big THANK YOU to all the masters here. I can watch the BPL channels very well and am very grateful. Suppose that's the least I should do lah...
    • DBTraitor
      • Feb 2011
      • 616
      #662
      Remember to help those in need also
      A wise man learn more from a foolish question than a fool can learn more from a wise answer.
      • shingo86
        • 17
        #663
        Originally posted by ypvs125
        Hi can u do a comparison on these two bouquet on ch226-ch228.
        Set 1.zip
        E2 Bouquet 16AUG13.zip
        Tried. Both are jerky. But set 1 is more jerky. Guess i stick with set 2. Will try a different cable etc tml. Really ty so much for helping
        Edit: please dun kill me guys.. I cleaned the head of my cable, box and cable point. Now it works flawlessly. Just in time. Tks everyone for the help esp ypvs125 & uu161.
        Sent from my GT-I9100 using Tapatalk 2
        • redarmy10
          • Sep 2012
          • 4
          #664
          Hi i cant seem to connect my clone box to the box edit. what ip address should i put??
          • uu161
            • May 2012
            • 372
            #665
            which why i say 135 won't work for you hehe
            i was just about say due ur signal is weak
            good to hear cleaning tips posted by 1ZM00601
            if you like the post use the Like button located bottom right corner of each post
            if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
            • Arraysys
              • 173
              #666
              Originally posted by avo24
              Any guys here try before the cable tv amplifier (booster) . Is the product good? I can't watch any soccer channel signal show 30.6db only.. could I buy the booster to boost my signal ?? Have fun watching soccer
              My colleague tried and it works. There are many brand/type and you just have to get the correct one. Cheers.
              • uu161
                • May 2012
                • 372
                #667
                1 simple way to know turn off /on and press hold power button the lcd will pop ur ip address ( for E2)
                anyway guys pls take note this thread are more about DM E1 & E2 SGSH Bouquet ( not for others brand box )
                i think is very messy already with alof OT
                • redarmy10
                  • Sep 2012
                  • 4
                  #668
                  erm..... but mine is a clone set. No lcd tried using 198.168.0.104 also cannot.
                  • windeleon
                    • 11
                    #669
                    just a tip for those who wan to watch hd content but only got 500c
                    this is what i do last time..
                    those who wants to watch bee pee L can try this method
                    connect up PC > router > box
                    dreamboxedit the hd channels into ur 500c
                    use VLC player on PC to watch
                    • garynges
                      • Jun 2012
                      able to use a mac to flash?
                      • flye
                        • Dec 2011
                        • 22
                        #671
                        also got this problem, 3 channels are very bad.
                        i plug in my signal booster that i bought sometime back and test, now all channels can see.
                        this is the one that i use:
                        1 Port Active Return Cable TV Digital Signal Amplifier 5 42 54 1000 MHz | eBay
                        • ahbenghero
                          • 32
                          #672
                          Have updated the new bouquet provided by uu161. But seem to be prone to green screen of death every now and then, quite unstable.
                          After watching a channel for a long period of time, when changing to another channel, it will hang...
                          Any idea what happened?
                          • Asbar
                            • Jun 2012
                            • 60
                            #673
                            hi guys.. those having problems can try this bouquet.. i download this bouquet through sgsh updater plugin 2-3 weeks ago.. it works for me till now on all channels & most importantly B*P*L channels.. no distorted images.. hope it works. really really sorry if didn't work.. my 1st time.. credits goes to sgsh updater & bouquet updater masters.
                            Bouquet 06082013.rar
                            • ypvs125
                              • Dec 2010
                              • 506
                              #674
                              Is is not a bouquet problem, sometimes could be yr image or hardware. Dm800 have the tendency of getting hot easily so advisable to cool it down and this could be the factor leading to the hanging issue.
                              • mnbvc789
                                • Dec 2012
                                • 6
                                #675
                                Originally posted by Jackaligga
                                wow, i must have missed it . Is it from a different thread? Where can i can the E1 bouquet?
                                yeah any for E1?
