Q5 HD PVR Cable Receiver latest Bouquet with BPL
This topic is closed.
I've not yet read the posts after this one yet so not sure if you've been answered. To get into the active protocol you need to go to setup>Network and once inside the network area press 3453 which will let you into the area you need.
HI to all, Ive just read every post here regarding this box. I am in the UK and have been given one of these boxes to try out. It appears to be running a different or custom firmware from what ye guys are using Software :1.20 June 24 2013 Boot & Loader are version 1.00.
Blue Panel or blue button is disabled telnet prompts for a username for which i cannot get past. All attempts to get into the 5erver or client section have failed. I can access the box using the q5tools.exe but dont want to change anything as the box is not mine. All UK full Nagra 3 channels are working on this boxes current setup and removing the ethernet cable will stop these channels from clearing so there is an active protocol in the box but I cannot see it. Ive also tried the different combinations of remote buttons such as menu>info>2222 but none of these work either. Scanning channels on this box the way it is set up is a really sloooooooowwwwwwww process. I know the cables.xml can be changed but as it is the only way to find all of them in the UK is a Bruteforce scan.The epg does not work at all but now and next does occasionally work. On the whole good box fast channel change ...Anyone else in the UK using this set top box or knowing how to access the secret menu please send me a pm ...Thanks BMComment
Thanks, got it sorted now.
Spoke too soon. When I connect the Q5 to my tv via a hdmi cable I dont get any sound but if I connect it through an amp with the same hdmi lead the sounds comes through the speakers. I was wondering if a firmware upgrade would sort this and does any one know where to get said upgrade?Last edited by liverlee; 16 January, 2014, 01:26.Comment
Hi guys, can anyone tell me how to use the channel editor? A lot of my UK channels have changed transponders but I have no idea how to add these back in to my customized favourites list under MOvies, Sport etc. Also, you can't sort the channel list alphabetically which is just plane annoying. Any tips greatly appreciated. Thank you!Comment
To sort each favourite channel list click RESORT CHANNEL the select which list you want from the drop down channel list then select move down or move to and put the number where you want it to sit.
It's easy to do from the receiver as well. It just takes time.
Any bro would like to share the different between MVHD and Q5? I am interest to get a q5... please pm me where to get thanks....Comment
-MVhd(dishonest) don hav all a lot of HD channels and they will ask u to pay them subscription after full n3.
-Q5 (got to find out yrself)
Q5 use to hv a better quality but recent productions r no better. They share the same s***r provider too.
Sent from my GF-2 using TapatalkLast edited by jatrophaseed; 30 January, 2014, 04:02.Comment
Off topic: if i have icam account for MVHD, how can i use it on my DM800SE?
Sent from my GT-I9305 using TapatalkComment
Correct, anyone talking about servers again will be banned, as we have given enough infractions and warnings at this stage!
Plus the thread will be closed if it continues down this route.I refuse to answer that question on the grounds that I don't know the answer. - Douglas AdamsComment
