Q5 HD PVR Cable Receiver latest Bouquet with BPL
This topic is closed.
  • SGDVB
    • 210
    #286
    Originally posted by Ben2409
    It is AMLOGIC Cortex Dual Core Neon CPU with MALI400 Quad Core High Performance 3D HD GPU.
    For those who have a computer at home, you may want to install XBMC Media Center to watch live stream of BPL, don't need to invest into media box.
    Juz my 2 cents.
    • SGDVB
      • 210
      #287
      Originally posted by moronicgenius
      MVHD oledi have this feature under x-function. only waiting for someone to setup connection pt...
      This is provided that the lan port is working.
      As far as I know, there are some batch of boxes (i.e: FYHD, MVHD), the port is only for show but not working or connected on purpose by unethical manufacturer & seller who knows it. They just waiting for the time to come (when workaround is available), they will claim that you box is faulty therefore cannot work with the solution that is available & offer you to buy new box.
      This have already been warned many many time not only by me but some other master here yet we still have naive ppl here buying from these unethical seller claiming that their box will work.
      I'm expecting some trader here to zapp me which I wun care as I'm just stating the facts.
      It will be best if we can boycott these box from unethical seller (i.e: FYHD, MVHD, TNHD & etc). This is not way to do business just like those who milk $$$ & sell card every 3-6 months in the past.
      • DBTraitor
        • Feb 2011
        • 616
        #288
        navi-x
        Media Streaming Addon for XBMC & Boxee
        A wise man learn more from a foolish question than a fool can learn more from a wise answer.
        • croc
          • Jul 2012
          • 70
          #289
          Originally posted by jatrophaseed
          Hi Master Croc, u r very very correct that 11thNov2013 many chn going out liao. Thanks for your PRE-information.
          hi master ...saw this morning 866 877 and 222 still got? wch channels will remove instead?
          • Tisankongjian
            • Mar 2013
            • 24
            #290
            Sg traders that r not informed by yr overseas counterparts that u will need the LAN port for the so call "workaround" and that the old boxes can be reuse(provided that the LAN port is not for display only).
            Sad to say, u could be the biggest fxxls , cos u are fxxled to fxxl on yr fellow countryman.
            open yr eyes, look elsewhere.
            • moronicgenius
              • Jun 2012
              • 54
              #291
              mvhd lan works oledi tested.
              • SGDVB
                • 210
                #292
                Sad to say, I was never a fool & was not fooled by them as I never purchase any of their box before since they told me about their plan to milk $$$.
                Lastly if I'm out to fool anyone to buy these box, will I be saying all these facts now? Please post any comment by me recommending this box.
                • SGDVB
                  • 210
                  #293
                  Well... Good for you then.
                  But wonder how you test the lan port since this box does not even have an software that link a PC to the box for editing. As far as I know, the so-called workaround for this box is not even available yet therefore how can you be so sure.
                  Maybe you have your way to test. I'm not technically or electronically savvy but just advising based on what I know from the maker of these box.
                  Last but not least, what I have said is a batch (approx. 1,000-2,000 box) not all box that is affected. If anyone is unsure about it, it will be best not to get the box unless you can be very sure the lan port is working or can get refund if the port is not working.
                  You have been warned. Thank you!
                  • moronicgenius
                    • Jun 2012
                    • 54
                    #294
                    use it to watch youtube so lan muz b work. juz 2 share wif other mvhd users in case they r not aware, tried the x-function wif info from free or test sources (taboo subject here so can't talk too openly) input the relevant info and box says connected but since its not S H so can't c b p l still but at least tested n x-function seems to work as a client box. now only need a s h "connection point" to fully test it. any of the 10 bros can help? hehe. so the solution advertised by the suppliers for this box is basically the same sats solution, only they provide half the solution so waiting for them or someone to provide the other half of the solution. this is juz 4 friendly info sharing based on my limited knowledge so I may be wrong and welcome FRIENDLY discussion. no need to argue abt anyting as all bros here no matter using which box ultimately juz wan free tv (but now no choice need to paid cheaper sub, if n when the connection points r up n running)
                    • SGDVB
                      • 210
                      #295
                      Almost forget that this box have youtube & other tube available. You are right, you have your lan port working.
                      • albert95
                        • Feb 2011
                        • 27
                        #296
                        Hi SGDVB,
                        Kindly enlighten me which adds on on video should i download in order to stream BeePeeL...I have dl xbmc but cannot find any suitable adds on to stream...tq
                        • SGDVB
                          • 210
                          #297
                          Originally posted by albert95
                          Hi SGDVB,
                          Try addons of Navi-X, SportDevil.
                          You won't be able to find these addons unless you install some useful repo. Try superrepo.
                          Google is the best way to find them.
                          • albert95
                            • Feb 2011
                            • 27
                            #298
                            thanks for your 2 cent...sgdvb
                            • netaccess
                              • Dec 2012
                              • 13
                              #299
                              HI, Is there any addon for taiwanese and hong kong channel?
                              i tried to search but there seems to be nothing around
                              • jatrophaseed
                                • 589
                                #300
                                i remembered i install a Merlin 3 dm800 image hv laliga, eurofootball, bpl, etc on al ajeela sports chns, more than 10 of them, dl_stream with fibre 100m was good but i lost that file. cant remeber where i got it. Perhaps google u can dl that wonderful iptv streaming image. Juz a suggestion even after n3, dm still can use as iptv altoh not as good. but it better than use it as doorstop.
                                Got it, but all in turkish movies, sport etc.
                                Link: *****************
                                enjoy.
                                Last edited by satsmo; 15 November, 2013, 21:29. Reason: Removed link to forum of similar content!
