Q5 HD PVR Cable Receiver latest Bouquet with BPL
This topic is closed.
  • croc
    • Jul 2012
    • 70
    #241
    Originally posted by jatrophaseed
    Thanks yr info, lately bz so not very upto date. Still, cable is not dead yet, enjoy while still avlb.
    Other then d chinese iptv box, with vpn we hv Hulu & netflix oso.
    Hi master...
    just a update....After 7~10 Nov should be only n3...cos my friend got the retail box and was told die die must take rental setup box and sh say after 7 nov ...migration is done and no one with retail boxes can see liao
    ...now migration is going by batches
    • jatrophaseed
      • 589
      #242
      my data log show 3rd Nov last day (+/- 7days = 10th Nov) of (HD) N1 subscription, after this date most N1 box (HD) from SH will die out and they hv to exchange for New type of HDbox. So I assume Nov to early Dec will see full migration. What it means is dat no N1 (SD) subscription is recvd by SH since 10th Oct, last date of activated N1 (SD) card ends 10th Nov + 7days(Grace period) = Max by 18th Nov NO MORE N1 (SD). give or take few days only. ie Max 2wks more of (SD) N1.
      Oh yes, HD will go off 1st. No HD sub since 1st Oct. so 7th Nov for HD last day.
      So yr friend is very correct.
      edited: Sorry for the mixed up HD/SD subscription.
      Calc: Paid subscription period + 7 days grace used by SH admin.
      I hv a record of those going out early but cant find it, but chn like BBC, CNN, HBO, VV drama............. r some going out 1st. from my no subscription ( end of subscription) log.
      My personal conclusion.... DreamBox N1 can b used in N3 as no hardware change , it is only the simple N3 encryption change hehehe..........
      Yes, i believe 1 day some young techies will be able to write an Atmega to fake/cheat the SK to generate the CW to get free views. But I am not going that way, too old liao, oso what I learned was last graduated in 1975 ( vaccuum tube/LSI era).
      Edited: SK = session key, CW = control word.
      • croc
        • Jul 2012
        • 70
        #243
        what abt those mvhd , fyhd?
        • jatrophaseed
          • 589
          #244
          mvhd, fyhd and all others die together lah.
          • croc
            • Jul 2012
            • 70
            #245
            so should we invest on a dreamox now or wait?
            • jatrophaseed
              • 589
              #246
              unless u know what to do, dont buy dreambox. there r many config n editing needed. very mafan linux entry many brother wont know. juz think, if a simple ftp of key files takes up 3x20 post, the new system will bolt down d forum.
              oso no tut allow to post cracking a Provider system.
              • parkhyomin
                • Nov 2013
                • 5
                #247
                Can anyone enlighten? Just on my q5 and suddenly thw shows are distorted. Hence I tried to NIT scan and still distorted. Any idea how to resolve? Plus. After I NIT scan, some of the channels no longer avail.. need help please..
                • Tisankongjian
                  • Mar 2013
                  • 24
                  #248
                  -check yr signal cable at the both ends, likely loose, turn it up tighly.
                  -yr set might be too old, retiring from its job.
                  • netaccess
                    • Dec 2012
                    • 13
                    #249
                    wonder if there are any slim slim chances that SH only upgrade the HD channels to N3 and keep the remaining on N2...
                    • Tisankongjian
                      • Mar 2013
                      • 24
                      #250
                      sorry i forgot,
                      -u might be using a splitter, use a SH approved quality splitter and cables also. They are available only in sim tower as far as i know.
                      -for channel nit scan it might not get all channels for u cos u did not provide quality signal to the tuner, thats y yr ch distort like pirated vcd?
                      -u can always load the ch via usb port, will be more than happy to provide u with the file, but i am not sure i can post anything here. so......u.... can p......me?
                      • Tisankongjian
                        • Mar 2013
                        • 24
                        #251
                        put yrself in SH position, will there be a slim slim chance?
                        • parkhyomin
                          • Nov 2013
                          • 5
                          #252
                          Originally posted by Tisankongjian
                          sorry i forgot,
                          The set is bought in august 2013. Initially for beepee. It was working fine with the splitter previously but until last night. Tried with my main sh set top box setup it was smoother but with abit distortion also.. c
                          • Tisankongjian
                            • Mar 2013
                            • 24
                            #253
                            - try bypassing the splitter and go direct to the wall scv outlet, if it solve the problem then u will know its the splitter giving u the problem.
                            - if problem persist, try now with a new cable(SH provided 1) with the above method. If this doest worked, it could be the tuners problem, contact yr seller. If they r local, they will
                            replace the set for u. It comes with a yr 1 to 1 warranty.
                            • parkhyomin
                              • Nov 2013
                              • 5
                              #254
                              Thanks! Shall try it when I get home. Hopefully its that problem. My seller says it could be software problem thou. Not sure if he will cover warranty. Its merely 3mths only.
                              • mitoev96
                                • May 2013
                                • 22
                                #255
                                sorry i forgot,
                                Hi Bro can enlight me what type or model is the SH approve splitter and cable. I too using splitter but the picture is not ideal therefore my room had no TV programme to watch. I hear that is a amplifer (Booster) to improve the signal. I had went down to sim lim tower and they just gave me those normal splitter type which I can get from my neighbourhood. Pls advise and Gam Xia
