FYHD 800c-vii latest firmware
  • Elan
    • Aug 2013
    Can't scan EPL channels on my new tnHD model HDC-888
    Hi Bros, Can't scan for the EPL channels on my set box. Is there any software upgrade done. Please guide. Desperate to watch EPL? Thanks.
    • tangdar
      • Aug 2013
      #77
      hi anathema, i have the exact model as chinwm and he's right. The setup box can't detect .AP files, it needs a firmware with .bin now.
      • sinibaba
        • Aug 2013
        #78
        Hi anathema and tangdar,
        If it's a bin file, will the 05082013-White-FYHD-MHD-usb_upgrade_app file. bin be able to update the FYHD 800-e? This is the file uploaded in the Singapore Dreambox page. Appreciate some advice, thanks.
        • tangdar
          • Aug 2013
          #79
          not too sure about that sinibaba, i'm using HDC-800. might work for you but definitely didnt work for us
          • anathema
            • Aug 2013
            • 13
            #80
            Let us know if it works out for you. I understand it worked for HDC-800C.
            • RVP
              • Aug 2013
              #81
              Originally posted by cyrus666
              Pls use this fw for now.......https://www.dropbox.com/s/8m4tv1udlc...pgrade_app.bin
              till there is further update.
              thank you
              PS: fw changed to the one posted in fy site.
              How do to update it on the box?
              • RVP
                • Aug 2013
                #82
                Hello everyone, I need help!! My box is FYHD-HDC-800e white box! When I tried upgrading the firmware provided by singapore dreambox website, it keeps stuck on boot and there's no image or channel on my TV screen. What I should do? Help Me!!!! Help!!
                • cyrus666
                  • Aug 2013
                  • 21
                  #83
                  this thread firmly states the fw provided here is for FYHD 800c-vii latest firmware i am not sure about your model
                  • phycomaticz
                    • Apr 2013
                    • 5
                    #84
                    Bro. This is fyhd 800 cii ? can use this latest firmware? This box very2 small. Only hdmi.
                    • cyrus666
                      • Aug 2013
                      • 21
                      #85
                      yes sure it works well with it.
                      • LQQK
                        • Aug 2013
                        Hi Guys
                        I've been going through the posts here and would like to share that for my 800c-vii set, all i did was updated the fw and autoscanned and managed to get all b*p*l channels. First 6 channels were in the early 900s (showing meeyostaydeeyurm) and the the next 2 channels were a few channels up with no channel descriptions. The fw upgrade did the trick.
                        The quality was not very good and choppy initially. Changed to a better quality hdmi cable. Solved.
                        However, someone else with the same model, did the same upgrade and same procedure, could only get the first 6 channels. Might be due to signal strength. Will update if a change of cables solved his problem.
                        Just sharing with the rest here.
                        • wongmf
                          • Aug 2013
                          #87
                          I encountered the above same problem while trying to upgrade my FW for same model . Anybody can help?
                          • badboys8908
                            • Feb 2013
                            • 7
                            #88
                            Originally posted by Crazyhanz
                            bro just to check. Is your's the white colour box?
                            White MHD600C. Just bought it 2 weeks ago with updated 05082013 firmware....sorry for the late reply...cheers
                            • Menifestozz
                              • Aug 2013
                              • 4
                              #89
                              I'm using FyHd800C-ii but cannot update using the firmware provided. After selecting the .Bin file it reboots and back to channel 101. Check firmware still the same. Dunno why it can't flashed. It didn't show any updating screen.
                              • Pokemon999
                                • Nov 2010
                                • 35
                                #90
                                You might want to refer to this thread for some tips.
