thanks for the advice, il do it all 2mo and get back to you..... zzzzzzzzzzzzzzzzzzzzzzzzzzz
Starview 5 - firmware
nice to see some people read first to get the answers well done m8
I have had my Starview box for about a year now, i thought it was a 5 but now i'm not sure as someone said the 5 has only been out 6-8 months.
The box says "TheBox Super USB" on the front. The reason i need to know is because some of my channels have stopped working. I've tried the manuel delete and reboot, factory default and setting the default key in the secret menu.
Can anyone point me in the right direction?
Thanks Vaders
also don't know if this will help but i'm in the Manchester area...Comment
super usb is version 4, it should have no rs232 (com port, 9 pin) on the backI have had my Starview box for about a year now, i thought it was a 5 but now i'm not sure as someone said the 5 has only been out 6-8 months.
Thanks Vaders
version 5 has usb and rs232 on the rear
some useful info..
contrary to what people say/believe there IS also a clone/bodge up of starview 5 (of sorts)
ive seen two, so, rare.. but they exist...
what that is is a starview 4 board (u can tell its a starview 4 board without looking at the circuit layout in that it wont have an rs232 port on the rear) but the front fascia will read TheBox USB II. yes, i know.. strange.
the bootloader/software is replaced with the bootloader/software of the version 5 unit, and hence it will look exactly like the sv5 on your tv when you boot up the unit.
as the starview 4 was also cloned, it gets very complicated and often faults are very difficult to rectify on these as u can imagine. steer well clear from these.Comment
should be just vermin messing about but its the start of the end.I have had my Starview box for about a year now, i thought it was a 5 but now i'm not sure as someone said the 5 has only been out 6-8 months.
Thanks Vaders
have you done a rescan as well? and make sure keycode is on..YNWA..Comment
Before chucking out the window !!!!!
hi folks i had a prob with starview box super usb2 in that it wouldnt recognise file on the usb stick.
Tried putting the file on a different stick and it worked first time so up and running.
give it a try
had a feeling it was an sv4.. sounded like it
no fix for n3 yet in 'chipped box' form unfortunately, enjoy ur sv4 while it lastsComment
my starview box has gone off
Hi all i am new to all this i bought my starview 5 in sept 09 and this is the first time i have had a problem with it i have tried reloading the original settings ithat i used but all the pay channels are still locked can anyone helpComment
Pensioner newbie. Had old Starview for 4 years, easy to update without ' usb firmware ', just purchased Starview 5 usb 2 and do not know what firmware is or how or where to find it. I haven't lost all my marbles yet but I am not P.C. technically minded. Hope you can help.Comment
Its straight forward enough m8 checkout the downloads section get the tut for sv5 posted by myself also get firmware for sv 5 v.2.03 that is the most stable dont use 2.05 if you find it its very buggy read the tut and follow it DO NOT INSERT or REMOVE USB Devise while the box is on REMEMBER that.If you need more help we are here to help you should be ok if you do as i have posted here take your time i hope your area is not Nagra 3 if it is the box or any other box is no use to you m8.If i have helped you please dont post Thanks just use the Thanks buttonComment
