cant extract file because its corupted.
Blade Media 7000s patched firmware 05/01/2012 81x
Only problem im finding with the new firmware is the 7 day download epg some channels give you the next day epg but none of them give u the 7 day.Any ideas anyone?.Comment
that option works fine on a blade if you select any epg portal channel on 28e before starting the epg downloadComment
to get 7 day epg on 28e do the following :-
first scan in transponder 11778V 27500 , and look for the channels like 8010 or portal video 5 that have sly trailers and info
select that channel , then press ok and do an epg update and it will download the 7 day epg for you
then select the guide and alter the epg as you wish using the coloured buttons
always select that channel to do the download , when required , as it uses it for its epg informationComment
When I try to do this, I get a insufficient Transponder Memory error in the manual channel option, In fact if I go to satellite search to do a full scan of 28.2, it only scans one Transponder, finding about 5 channels.
Have factory reset the box and tried again but still the same.Comment
you didnt state which patch you were using , but if its this latest one , factory reset the box and try the latest OFFICIAL FIRMWAREWhen I try to do this, I get a insufficient Transponder Memory error in the manual channel option, In fact if I go to satellite search to do a full scan of 28.2, it only scans one Transponder, finding about 5 channels.
if the fault still persists , contact blademedia.tv or your supplierComment
downloaded again and all good.. Very strange
