bit of advice on motorised dish
the motor manual should tell you about the dish "bit" , typically the dish will be about 27.5 degrees but can vary from maybe 22 to 30 degrees depending on location, so check your motor manual
so the motor is locked onto your latitude in degrees , so maybe around 51 to 53 degrees depending on your GPS, the dish somewhere around 27 degrees on its marker, the lnb has no skew when on zero , typically use thor as your starter sat but use usals with your gps locked into your box settingsComment
if you are in the UK then 44 will be wrong as the UK latitudes are in the fifties , usually between 51 and 55 but you can check yours on dishpointer or using a satnav or app on your phone, these will tell you your longitude and your latitude, its imperative that you use these on your equipment
44 degrees is the south of france, like toulouse or bordeaux
I would also leave the sly dish up as it can be useful to have this as well as the motorised dish , especially for a multiple input receiver
you can use a diseqc switch and have the motor on one lnb input and the sly dish feed on another lnb input, with the common going to your boxLast edited by ramjet; 11 January, 2014, 09:59.Comment
well recut the wires, like on the you tube vids and absolutly nothing still. im leaving it for tonight and having a cold beer and some xbox time. but tomorrow i need to figure this out, going to try a ready cut wire from the market and see how that does to fully rule it out, will have to send back to the seller if not sorted for a replacement
but iv noticed my dish also has a degree marking on it of some sort, iv set it on the motor but cant find anything about the dish bit
