you can line it up on any sat you like
but as your location is about 3w you should really try to line it up on thor at 0.8w or the sat at 5w as these are close to your zero marker on the motor
if using the same alignment as your sly dish , is astra 2 , not astra (astra is 19e not 28.2e)
ideally you should have marked the pole mount , motor , dish mount etc with a black marker when you had it on thor and the motor was showing 2 east
roll on sat
