Cloud ibox unbranded solo clone
  • sjuran
    • Oct 2013
    Originally posted by calcu
    this may sound silly but...
    which side of the cable is attached at the pc and which is at receiver?
    pin 2,3,5- PC
    pin 6,4,5- Vu+ (CLOUD IBOX) ..... adapter in VU
    • radmir
      • Oct 2013
      Originally posted by kkkkklaur
      For working with lathest sowtware image is need to use the lastest upgrade FERRARI security chip to v3.2 READ THIS
      ???? It can't work! At least becouse ibox has only 3 pins in serial port conector. And it has different security chip inside, not ferrari.
      • billalahmed
        • May 2010
        • 15
        #303
        any1 got hold of the cloud ibox 2? are they anygood and do they support the latest vix image? they seem to have the same chassis as the dm800.
        • digicon
          • 8261
          #304
          The Cloud ibox2 is a clone of the maxdigital XP1000 receiver
          • lombard
            • Aug 2008
            • 793
            #305
            hi you sure as spec seems higher
            Cloud ibox2 Powered by a 600Mhz Broadcom MIPS CPU, 4G DDR 3RAM and 2G flash. 3D,PVR ready,
            Supported officially by OpenPLi, OpenAAF and the ViX Team.
            support 3D ,3G,USB,WIFI,HBBTV,Youtube,IPTV,Emu firmware.
            and another version
            Cloud ibox2 Powered by a 600Mhz Broadcom MIPS CPU, 1G DDR 3RAM and 1G flash. PVR ready,
            are they really supported officially ?
            • satsmo
              • 6397
              #306
              I have just deleted numerous posts quoting "other" forums. Next time will be an infraction followed by a ban for those that continue to do so.
              • MENTE SICULA
                • Sep 2013
                • 18
                #307
                ok sorry satsmo
                is someone want try new Black Hole Image 2.0.6 patched by Toyfot (all thanks go to him)
                can read here and leave same feedback
                Vu+ Solo : BlackHole 2.0.6 Ferrari V2/V3 by Toysoft
                • balbao
                  • Oct 2013
                  #308
                  UPGRADE v3 to v3.2 is ONLY! for receiver with v3 security chip inside..
                  For receiver v1 or v2 security chip inside is neeed hardware(not software) upgrade (new upgrade with chip v3.2)
                  hi, how to know the security chip version? is there any way to find out?
                  • kkkkklaur
                    • Sep 2013
                    • 9
                    #309
                    Search with google this......
                    8a8f8
                    and in first link IN RANK you find answers....for security chip Ferrari receiver....
                    Receiver CLOUD producer sell cloud ibox have v3 chip inside
                    search this in google...
                    Original Ferrari Chip Cloud Ibox Version3
                    ......and 2 link in rank is AIRSAT CLOUD IBOX V3 chip
                    Upgrade how to ( source:Ferrari forum)
                    Use the RS232 cable and dongle type device (or modified null modem cable with pin explain in page 20 in this thread)that came with my box to update the firmware to the latest v3.2.
                    To do this make sure your computer has a real physical COM port, USB adapters won;t work reliably and that the OS is Windows XP.
                    Make sure the Vu Duo is switched off, plug the RS3232 dongle into the Vu Duo, plug one end of the cable into the dongle, the other end into the COM port on the PC/Laptop.
                    Download the latest v3.2 firmware and unpack to a suitable location and then run the program renewaes.exe, this should automatically detect the COM port, if it doesn;t then you have a problem so check all connections.
                    If the program detected a COM port then you can continue so click on Load file and select the file vu_2ver_22m_130110_sec_isp.bin.
                    After the file has loaded switch on the Vu Solo/Uno/Duo, the program should start flashing the firmware to the v3 security chip, a progress bar will be displayed and a message will pop up when the Update has completed.
                    The box is now ready, so go and get whatever image you want to use then use the normal USB method to flash the box and then enjoy.
                    For download the update security pack (v3 to v3.2) search in google this
                    V3.2 upd_vu62k.zip
                    This information is only for educational use and Viewing Pay TV without a valid subscription is illegal
                    • kkkkklaur
                      • Sep 2013
                      • 9
                      #310
                      In the future arrived CLOUD IBOX II (Shenzhen Air Digital)
                      clone of Receiver MK DIGITAL XP1000 (or MAXDIGITAL XP 1000)
                      • MENTE SICULA
                        • Sep 2013
                        • 18
                        #311
                        it will take imagine VU+ ?
                        • kkkkklaur
                          • Sep 2013
                          • 9
                          #312
                          Appear on AliExpress as the sale has not yet appeared in the Chinese say Officially Supported by OpenPLi, OpenAAF and the ViX Team and how we see that first to see if the price is competitive ....
                          • digicon
                            • 8261
                            #313
                            Its a Clone of a NON Vu+ receiver so will not take any of the Blackhole images only image supported are those mentioned above
                            • Pillhead
                              • Dec 2010
                              • 71
                              #314
                              The New CLOUD IBOX !!!The best affordable receiverSimilar to VU+Solo ans DM800HD
                              V.3 : Buit-in fan
                              Satellite and IP Channels Receiver
                              My alien 8900 box has just gone kaput and ive been offered one of these as a replacement? Apparently its a newer model that runs cooler. Probably just the same but with a crappy fan installed.
                              I dont mind doing a bit of modding myself if it needs a new or larger fan etc.
                              BUT does the current firmware run stable on these boxes now? Ive read most of this thread!
                              Cheers guys and gals
                              • bighun
                                • Nov 2010
                                • 151
                                #315
                                i am running both the openbox s6000hd and a cloud ibox both have the v3 chip in them and i am running ferrari blackhole 2.0.6 which they run perfectly the s6000hd has not got a fan in it and runs a wee bit hot the ibox has a fan and it is virtually noisless i am running a lot of plugins also for the price they are a cracking wee box
