Cloud ibox unbranded solo clone
???? It can't work! At least becouse ibox has only 3 pins in serial port conector. And it has different security chip inside, not ferrari.Originally posted by kkkkklaurFor working with lathest sowtware image is need to use the lastest upgrade FERRARI security chip to v3.2 READ THISComment
any1 got hold of the cloud ibox 2? are they anygood and do they support the latest vix image? they seem to have the same chassis as the dm800.Comment
hi you sure as spec seems higher
Cloud ibox2 Powered by a 600Mhz Broadcom MIPS CPU, 4G DDR 3RAM and 2G flash. 3D,PVR ready,
Supported officially by OpenPLi, OpenAAF and the ViX Team.
support 3D ,3G,USB,WIFI,HBBTV,Youtube,IPTV,Emu firmware.
and another version
Cloud ibox2 Powered by a 600Mhz Broadcom MIPS CPU, 1G DDR 3RAM and 1G flash. PVR ready,
are they really supported officially ?
ThanksComment
I have just deleted numerous posts quoting "other" forums. Next time will be an infraction followed by a ban for those that continue to do so.I refuse to answer that question on the grounds that I don't know the answer. - Douglas AdamsComment
ok sorry satsmo
is someone want try new Black Hole Image 2.0.6 patched by Toyfot (all thanks go to him)
can read here and leave same feedback
Vu+ Solo : BlackHole 2.0.6 Ferrari V2/V3 by Toysoft
Search with google this......
8a8f8
and in first link IN RANK you find answers....for security chip Ferrari receiver....
Receiver CLOUD producer sell cloud ibox have v3 chip inside
search this in google...
Original Ferrari Chip Cloud Ibox Version3
......and 2 link in rank is AIRSAT CLOUD IBOX V3 chip
Upgrade how to ( source:Ferrari forum)
Use the RS232 cable and dongle type device (or modified null modem cable with pin explain in page 20 in this thread)that came with my box to update the firmware to the latest v3.2.
To do this make sure your computer has a real physical COM port, USB adapters won;t work reliably and that the OS is Windows XP.
Make sure the Vu Duo is switched off, plug the RS3232 dongle into the Vu Duo, plug one end of the cable into the dongle, the other end into the COM port on the PC/Laptop.
Download the latest v3.2 firmware and unpack to a suitable location and then run the program renewaes.exe, this should automatically detect the COM port, if it doesn;t then you have a problem so check all connections.
If the program detected a COM port then you can continue so click on Load file and select the file vu_2ver_22m_130110_sec_isp.bin.
After the file has loaded switch on the Vu Solo/Uno/Duo, the program should start flashing the firmware to the v3 security chip, a progress bar will be displayed and a message will pop up when the Update has completed.
The box is now ready, so go and get whatever image you want to use then use the normal USB method to flash the box and then enjoy.
For download the update security pack (v3 to v3.2) search in google this
V3.2 upd_vu62k.zip
This information is only for educational use and Viewing Pay TV without a valid subscription is illegalLast edited by kkkkklaur; 9 October, 2013, 22:47.Comment
The New CLOUD IBOX !!!The best affordable receiverSimilar to VU+Solo ans DM800HD
V.3 : Buit-in fan
Satellite and IP Channels Receiver
My alien 8900 box has just gone kaput and ive been offered one of these as a replacement? Apparently its a newer model that runs cooler. Probably just the same but with a crappy fan installed.
I dont mind doing a bit of modding myself if it needs a new or larger fan etc.
BUT does the current firmware run stable on these boxes now? Ive read most of this thread!
Cheers guys and galsComment
i am running both the openbox s6000hd and a cloud ibox both have the v3 chip in them and i am running ferrari blackhole 2.0.6 which they run perfectly the s6000hd has not got a fan in it and runs a wee bit hot the ibox has a fan and it is virtually noisless i am running a lot of plugins also for the price they are a cracking wee boxComment
