SGSH Bouquet 500C/800HD/800SE
This topic is closed.
  • ASTROBOX
    • 163
    #436
    Originally posted by Innercy
    Can anyone kindly update the bouquet with the new Japanese channel 149 for DM500c?
    You can download from 1st page i updated just as bro uu mention might be the last update before N3 so just enjoy while u can
    • Cshnyt
      • Jun 2012
      • 9
      #437
      wonder if i'm alone on this issue
      i cannot watch HBO HD recently and only this channel has a problem all other channels are working great and i meant all the other HD and non HD channels ?
      any idea how i can fix it ?
      • jasper89a
        • Feb 2013
        hello guys. im new to the thread. how do i go about adding the bouquet?
        • chrome08
          • Jan 2013
          • 13
          #439
          Hi Guys,
          I know that for DM500C, the link to the picons are....
          /var/tuxbox/config/enigma/picon/
          Can someone please guide me to the picon folder for DM800?
          Thanks.
          • Bomchacha
            • Feb 2013
            • 117
            #440
            usr/share/enigma2/picon
            • presto80
              • Dec 2012
              • 15
              #441
              i tried the new bouquet for march but i am hit with the error.
              anyone can help?
              thanx
              • w3irdo
                • Jun 2012
                • 5
                #442
                Hi, i also downloaded the new bouquet . many channel lost.. then i opened the bouquet , found out many channel without freq. where to dl the correct bouquet?
                • ASTROBOX
                  • 163
                  #443
                  Digital Kaos - Downloads - SGSH 06032013 E2 800 & 800SE + Picon
                  Try dowload again i re upload & tested it seems fine now
                  Sorry for the inconvinience I'm not sure what happen but for E1 no problem just E2 bouquet only
                  • w3irdo
                    • Jun 2012
                    • 5
                    #444
                    ASTROBOX u are so efficient.. the new file is working
                    • flippydreamer
                      • 17
                      #445
                      Too bad the users won't be able to key in the channel numbers and go to their specified channel.
                      • mikeleehm
                        • Mar 2013
                        • 7
                        #446
                        Hi All
                        My box is a DM800HD SE, and I can see most of the SH channels BUT there are quite a number of Reserved channels.
                        Is there anyway to get updated channels?
                        • uu161
                          • May 2012
                          • 372
                          #447
                          Originally posted by mikeleehm
                          Hi All
                          Reserved channels are act as a dump channel for sh channel number running in order ( for manual enter channel number by remote control )
                          if Reserved channel are del when manual enter sh channel number by remote control turn out to be like rojak ( which mean sh number are not running in correct order )
                          check post 1 . is better to read thr the 29 pages am sure u will know how to update new channel by then.
                          even a video guide are there posted by master DB
                          if you like the post use the Like button located bottom right corner of each post
                          if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
                          • sneezereer
                            • Feb 2013
                            • 11
                            #448
                            A quick newie question - how come most of the channels in the bouquet-list are blank and empty after select & <OK>?
                            Is it one on my DM-box 'connected SCV cable pipe trunk' subscribed these channels?
                            • duntellu
                              • Aug 2012
                              thanks will give it a try!
                              noob here btw
                              • yeeayu
                                • Mar 2013
                                very detailed, hope i can get it right.
