SGSH Bouquet 500C/800HD/800SE
This topic is closed.
  • tigsher
    • May 2012
    #586
    [QUOTE=resistive;2060121]SGSH Bouquet 14082013 E2[/QUO
    If you have splitter adapter, remove it. Connect the cable directly to the point. Or use a better coaxial cable 75 Ohm.
    At first, I also encountered the same issue like u, after I remove the splitter adapter and connect to the point directly. I received all 8 channels very clearly.
    • ayidaidy
      • Oct 2012
      • 5
      #587
      [QUOTE=tigsher;2060679]
      Yup...i seems to have the same problem b4 also..but direct connection without using splitter solved it..
      Sent from my GT-I9100 using Xparent Blue Tapatalk 2
      • paperdolls
        • Aug 2013
        • 6
        #588
        hi MASTERS!!!!
        PLEASE PLEASE HELP ME OUT!!!
        Before updating the channels downloaded from here, my DM800HD is still working fine but I was unable to edit the channels accordingly to s*H numbers. it is all jumbled up.
        I DID NOT back up my previous setup for bouquets DUE TO MY STUPIDITY AND NOOBNESS. I have now tried rescanning and rebooting and doing everything I can but its all to BLANK SCREEN!!!!!! i am only able to watch FTA channels like 5/8/u. I AM LOST. My SOFTCAM says NO ECM INFO despite downloaded directly from the TSPANEL 7.2 for MGcamd 1.38
        im on Philips CU1216Mk3tuner. the keys and scee is still intact when browsed but i have no idea if it was swapped or changed. and running on Newnigma 2 v3.2.2 experimental base. I HAVE NO EXPERIENCE IN FLASHING anything.
        Can somebody please please help me. I have been stuck and trying for hours
        • paperdolls
          • Aug 2013
          • 6
          #589
          hi MASTERS!!!!
          • swashbuckle
            • Aug 2013
            • 4
            #590
            Originally posted by paperdolls
            hi MASTERS!!!!
            did u try #3 and #4 in this -> http://www.digital-kaos.co.uk/forums...m-info-262981/
            • swashbuckle
              • Aug 2013
              • 4
              #591
              Originally posted by blindangel
              Thanks, but channel 234 is missing... Anyone can add on?
              anyone managed to get channel 234?
              • paperdolls
                • Aug 2013
                • 6
                #592
                Originally posted by swashbuckle
                hey sir,
                i dont understand anything about it and i am still trying for the 5th hour on to get the sh channels to show. i am only able to see the progress of the channels but its all blank screen. I am able to view all FTA channels.
                • swashbuckle
                  • Aug 2013
                  • 4
                  #593
                  hey sir,
                  Maybe you can describe, one step at a time, what u did that resulted in the problem? Then everyone can try to help
                  • ASTROBOX
                    • 163
                    #594
                    hi MASTERS!!!!
                    It's got nothing to do with TS panel, in the 1st place you should have just restart your cam that should do the trick & you can download from Newnigma plugin for mgcam no need from TS panel unless like some other images where server does not support softcam anymore. Sorry not in SG to do updating or what so ever now enjoying free TV via satellite
                    • mnbvc789
                      • Dec 2012
                      • 6
                      #595
                      Any updates to E1 - DM500?
                      • paperdolls
                        • Aug 2013
                        • 6
                        #596
                        hi sir,
                        can u please tell me what i can do...? i am not getting the points because i'm a pure noob!
                        • digi16
                          • Jan 2013
                          • 13
                          #597
                          Originally posted by ypvs125
                          Can't u do an automatic scan? It will pick all sh available channels on sr6875 and sr6090.
                          Master ypvs125,
                          My box DM800HD PVR. My image Cnigma2. My boutiques from UU!61's 3/4 August download. Tot i had 8 ch, but unlike 226-232 signal strength close to full bar, my 232/233 have no highlited signal bar. When open ch232, I can see the announcement page. Service info shows sr6090 freq 149500. Is this normal? How to manually tune just this ch and look for other frequency? Like if freq has changed for this ch, how to manually, or auto, search (for this ch only)? Does editing the freq in DBedit work?
                          Thanks,
                          Digi16
                          • ASTROBOX
                            • 163
                            #598
                            Press blue button on your remote there you can see a few option select restart softcam or mgcam something like that
                            • RedRidingHood
                              • Apr 2013
                              • 29
                              #599
                              Originally posted by jonzhong
                              hi bros.
                              im new and i do not know where to read from. i am using a DM800SE HD. i tried to follow this step by step instructions but i think i could not even get the basics (ip address of the dreambox correct). i connect the dreambox to my router and another cable from router to my laptop. still when i try to send the channels over, it will say unable to detect dreambox. ip address error. can any kind bros out there please guide me. i am fine if you guys can just link me to the link or a tutorial. i will read from there and try. thanks in advance
                              anyone with ******, i want this DM fast, supplier that know of any fedex 1.
                              • paperdolls
                                • Aug 2013
                                • 6
                                #600
                                hi sir,
                                i have rebooted the cam but it still doesnt display other channels. do i need to restart my box?
