Thank you ASTROBOX , abeltcb and ahbenghero for your tireless effort i am very noob, could anyone be kind enough to tell me what to do step by step? i am using dm800HD SE.
I want to update the channel list as what im getting now is in 5 digit
Thanks!
Hi, I'm new here. Sorry but the link for the newbie SG guide, is it dead?
Just gotten myself a plug and play DM800HD PVR clone. However a lot of the channels have this "tune failure" errors. I'm not sure if this matters, but I noticed that there are some numbers at the bottom of the screen info, and all these channels that hv the tune failure problem have numbers below 30.00, normally ard 25 or lower.
And because the seller forgotten to pack in our local 3pin adaptor, I am just using their 2pins one. Would it matter? So far not smelling anything burning. :x
Very sorry to bother u all, I did try reading and searching for the causes and solutions, but I simply dun understand most of the written stuff. Very overwhelmed by the technical stuff and jargons.
if you like the post use the Like button located bottom right corner of each post if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
All discussion on SGSH Bouquet only applicable to
Dream Multimedia (DM) 500C/800C HD/800C SE only.
Do not use this method if box is not Dream Multimedia model.
Edited & updated of SGSH channel list as of 31032013, added new channel
158 Zee News
Unknown date of commencing
231 IPL Channel
Commencing on 2nd April 2013 10.00pm
Rename 523 ITV Granada to 523 ITV Choice +
new picon
PROFILES:
option/profiles/new profile/set your box model & ip address/the rest just leave as default/test ip connection/after successful select enigma 2 setting for 800 series/cable receiver for 500 series enigma 1/save profile/save.
PICON:
Tick show picon for service/40X30 picon dimension/browse for where u put your picon folder/save.
As for sending of picon i prefer to send it manually using DCC program or if u know the folder u can send it using dreambox edit eg for 500C PLI images is var\tuxbox\config\enigma\picon type this in your picon box under option/profile/path for Picons in Dreambox
Select open/directories for your bouquet folder/ok.
Right click on all the channel list/ set keep flag option to ON/ok this is to keep the channel intact/u can go on edit the service data, under flag option only Tick the 2nd box H (hide) if u don't want the channels to be display on your box like eg. those demand channels/save.
When u done editing all the channel list + bouquet & u r sure about it ,select FTP/Tick auto reload setting enigma 2 for 800 series only/send files to Dreambox/Reload settings on Dreambox/Restart enigma.
For 500 series send files to Dreambox/Reload settings on Dreambox/Reboot Dreambox.
Do not create any bouquet for E1 500C or else u can't use the 3 digit direct channel selection.
There will be some minor mistake entry don't worry edit it,then send it again. Congratulation now your list is intact the same as SH channel list.
This is the way i normally do if u guys knows a better way or something i miss please feel free to add & correct me.
This is for those file that is already arranged post in dl section,for new scan will be more tidious & time consume but still a good way to gain experience arranging from scratch
Thanks to all senior & even junior for sharing their experience & knowledge.
Please read from 1st post for instruction on how to update box using this file.
All post is for experimental purposes use at your own risk.
Do backup your setting 1st before using this file.
All credits goes to masteruu161 & master jatrophaseed for the quick tracking of new channels, I just do a rescan & copy paste to the existing bouquet & also edit here & there.
Thanks master
Reason: add
