SGSH Bouquet 500C/800HD/800SE
This topic is closed.
  • Bomchacha
    • Feb 2013
    • 117
    #571
    Dreamboxedit for 800HD and 800SE - YouTube
    Ignore the picon part on the last portion
    Picon has to use ftp method to transfer. DBedit seems impossible to do so or at least I haven't manage to succeed.
    This video is just a rough guide, you should follow the instruction posted by Astrobox closely
    Latest DBedit program
    dreamboxEDIT 5.2.0.0 [Download]
    • terrysg
      • 30
      #572
      Originally posted by ultrakiasu
      Dreambox DM800 series definitely able to receive all the 8 channels of MioStadium.
      But remember that not all the tuner quality the same.
      Out of the 10 sets, about 2-3 sets would have issue recieving just 2-3 channels.
      Luckily I have cache of DM800 tuner modules.. swap the tuner module, and they can receive all 8 channels.
      So, if you owned a DM800 series set top box, and got the latest service files, and still see blank screen, likely be the tuner issue.
      For those who going to buy, please take note of this issue.
      Remind the supplier to use better tuner!
      Bro.. can you define quality tuner? If we ask the supplier they sure claim is good quality. So is there any specific brands or model of the tuner that has higher chance of receiving the HD channel? Your current tuner is which brand/model?
      Anyway possible for u to share the bouquet with BPL?
      Thanks in advance.
      • Kevann2679
        • Aug 2013
        • 4
        #573
        Thanks in advance.
        Philips and NXP tuners can watch BPL or not?
        • terrysg
          • 30
          #574
          The supplier told me nxp is Phillips tuner which is original dm is using and its better quality. However the factory that manufacture nxp has shut down so NUtune is being replaced and its R&D by china.
          • Kevann2679
            • Aug 2013
            • 4
            #575
            Oh... thanks... As I have got 2 DMs one with NXP Tuner and the other with Philips Tuner. So basically is the same then...
            • Kevann2679
              • Aug 2013
              • 4
              #576
              Originally posted by ASTROBOX
              All discussion on SGSH Bouquet only applicable to
              Dream Multimedia
              (DM) 500C/800C HD/800C SE only.
              Do not use this method if box is not
              Dream Multimedia model.
              Edited & updated of SGSH channel list as of 29072013,
              added new channel
              For E2 Box only
              463 Crime & Investigation Network HD
              464 The Biography Channel HD
              562 WarnerTV HD
              755 BBC World News HD
              760 CNN HD
              Added new freq 157 Symbolrate 6090 in cable XML useful for E1 user
              Box must connect to router
              In XML format for reference as of 29072013
              29072013 SGSH Channel List In XML format - Downloads - Digital Kaos
              For E1 DM500C as of 06062013
              SGSH Bouquet 06062013 E1 500C - Downloads - Digital Kaos
              For E2 DM800/800SE as of 29072013
              SGSH Bouquet 29072013 E2 800 & 800SE - Downloads - Digital Kaos
              Complete Tools/Program for Dreambox
              Open PD DreamboxToolbox v.9.0
              Open DB edit
              PROFILES:
              option/profiles/new profile/set your box model & ip address/the rest just leave as default/test ip connection/after successful select enigma 2 setting for 800 series/cable receiver for 500 series enigma 1/save profile/save.
              GENERAL:
              Tick box 1/3/4/enable zap function/save.
              Tick all box
              FTP:
              Tick enable quick ftp send/issue reload command.
              COLOR SCHEME:
              Select whatever color u like
              ADVANCED:
              Tick Allow duplicate entries / display reboot
              PICON:
              Tick show picon for service/40X30 picon dimension/browse for where u put your picon folder/save.
              As for sending of picon i prefer to send it manually using DCC program or if u know the folder u can send it using dreambox edit eg for 500C PLI images is var\tuxbox\config\enigma\picon type this in your picon box under option/profile/path for picons in Dreambox
              Select open/directories for your bouquet folder/ok.
              Right click on all the channel list/ set keep flag option to ON/ok this is to keep the channel intact/u can go on edit the service data, under flag option only Tick the 2nd box H (hide) if u don't want the channels to be display on your box like eg. those demand channels/save.
              When u done editing all the channel list + bouquet & u r sure about it ,select FTP/Tick auto reload setting enigma 2 for 800 series only/send files to Dreambox/Reload settings on Dreambox/Restart enigma.
              For 500 series send files to Dreambox/Reload settings on Dreambox/Reboot Dreambox.
              Do not create any bouquet for E1 500C or else u can't use the 3 digit direct channel selection.
              There will be some minor mistake entry don't worry edit it,then send it again. Congratulation now your list is intact the same as SH channel list.
              This is the way i normally do if u guys knows a better way or something i miss please feel free to add & correct me.
              This is for those file that is already arranged post in dl section,for new scan will be more tidious & time consume but still a good way to gain experience arranging from scratch
              Thanks to all senior & even junior for sharing their experience & knowledge.
              Brothers! This is what your are waiting for! BPL (EPL ) Channels! Update your bouquet today! Enjoy
              • mnbvc789
                • Dec 2012
                • 6
                #577
                Anybody has ch820 One English?
                • jonzhong
                  • 4
                  #578
                  hi bros.
                  im new and i do not know where to read from. i am using a DM800SE HD. i tried to follow this step by step instructions but i think i could not even get the basics (ip address of the dreambox correct). i connect the dreambox to my router and another cable from router to my laptop. still when i try to send the channels over, it will say unable to detect dreambox. ip address error. can any kind bros out there please guide me. i am fine if you guys can just link me to the link or a tutorial. i will read from there and try. thanks in advance
                  • resistive
                    • Aug 2013
                    • 4
                    #579
                    Originally posted by jonzhong
                    hi bros.
                    On your Dreambox (If newengima2 firmware see below, if not dig around in the settings/information menus)
                    Open Main menu > Setup > Network > Adapter Settings. I.P of the Dreambox is on the right pane.
                    Anyway longtime lurker here. Tried the 14082013 SGSH Bouquet on DM800SE with Philips tuner. Uhh 2 out of 8 BPL (namely MS CH107/108) can be seen clearly, others 6 channel no signal or distorted.
                    Tried to do a manual scan on DB, frequency 135 and 136. No way to input 0.5mhz. No signal or distorted.
                    So I guess my last option is to push the channel thru DBedit, found out I can't add service with 0.5 mhz again.
                    Question: How do I manually edit the service list that is going to be open in DBedit for upload?
                    • ypvs125
                      • Dec 2010
                      • 506
                      #580
                      Can't u do an automatic scan? It will pick all sh available channels on sr6875 and sr6090.
                      • resistive
                        • Aug 2013
                        • 4
                        #581
                        Tuner: Philips CU1216Mk3
                        Auto scan: 104 /105 /106 detected but distorted pictures. 5 CH undetected.
                        DBedit: All 8 CH detected
                        but 6CH distorted pictures . 2CH 107 / 108 clean signal.
                        Perhaps it's this particular tuner giving issue?
                        • ypvs125
                          • Dec 2010
                          • 506
                          #582
                          I am using same tuner with no issue. Which bouquet are u using when u detect all 8 channels?
                          • resistive
                            • Aug 2013
                            • 4
                            #583
                            SGSH Bouquet 14082013 E2
                            • blindangel
                              • Feb 2011
                              Thanks, but channel 234 is missing... Anyone can add on?
                              • Bomchacha
                                • Feb 2013
                                • 117
                                #585
                                hi bros.
                                Why do you connect your laptop to your router? Your laptop does not have wireless capabilities?
