SGSH Bouquet 500C/800HD/800SE
This topic is closed.
Check yr log file for error in dreamboxedit and post here. If u have entered the correct settings, u should have no problem transferring the files over.Comment
Erm...Hope I didnt sound like a leech...Just helping out...
I edited ASTROBOX's Bouquet and arranged how they are being categorized.
Do give some comments be it good or bad. =)
Oh...That is for 800 series only I guess...
This is a good alternative
for guys who keep asking about the reserved channels rather then pressing the red button. Thou the channels also could easily be deleted as mention by Astrobox.
Yes, kindly follow ypvs125 guide to revive the box
Selling it does not solve the problem.
Learning how to manage it will let you watch the box for a couple of years more if there is no change in SH key or system
A wise man learn more from a foolish question than a fool can learn more from a wise answer.Comment
What do u mean by brick can u specify in details what your box condition is now like can the box reboot? or just hang on start up screen? or from RCU no response?
Be more specific so that we can help u revive your box, as DB traitor mention no point selling the box, yes u can get a new box, after a while the same symptom or another symptom occur, U sell it again & get another new box?
But if the box is really brick by all means get a new set do u think someone will buy your brick box? I don't think soComment
Guys i have a HD800-C. I tried to update the bouquet using the page 1 instructions. I config everything to the exact point, but when I pressed the "send files to dreambox" button, the logs shows the below error message :
Connecting to 192.168.0.1.
Connected.
Dreambox response: User logged in.
** Getting directory list /etc/enigma2/* **
Starting FTP transfer
Transfer complete
** Sending file "/etc/enigma2/lamedb" **
Transfer aborted
Error sending file "lamedb" to the Dreambox.
Disconnecting.
Disconnected.
Pls advise? I cannot find what's wrong as I had read all the 8 pages here and 863 pages over at the SGStarhub Digital-Kaos Image ...Comment
i think i am, how to check if i am on enigma2 settings?
The outside of the box shows FYHD HD800-C
How to go about using FTP?
Thks in advance !!!Comment
Ok, for FY you cannot use dreamboxedit. Your box is different from what we discussed here.
You probably bought the wrong type of box. But nevertheless, you can still get all the SH channels. The only problem is that you cannot do any changes to the interface, skin or channels the way you want it.
So whatever we discuss in the forum is not quite related to your box.
Always go for the brand Dreambox for SGA wise man learn more from a foolish question than a fool can learn more from a wise answer.Comment
so sad ... so very sad ... thanks anywayOk, for FY you cannot use dreamboxedit. Your box is different from what we discussed here.
But my box not considered 800hd ?Comment
