SGSH Bouquet 500C/800HD/800SE
This topic is closed.
  • twiddlebug
    • Jul 2013
    • 4
    #541
    Originally posted by Bomchacha
    Yes,, you need to reflash using null modem cable
    okok thanks bro, SLT B1 can get right? just to check any usb to rs232 cables? the laptops i have all no com port one.
    • Bomchacha
      • Feb 2013
      • 117
      #542
      no laptop nowadays will have coms port. You wont find one laptop that has a coms port.
      • twiddlebug
        • Jul 2013
        • 4
        #543
        i got my hands on a null modem cable, connected to my desktop and could use dreamup to connect. As per other thread instructions, i flashed a pli-Jade image which the box was running previously, everything looked good, CRC check was ok, but box still showed solid green light. Followed steps in this thread, flashed the provide bouquet, all status msg was ok, box still solid green, pressing standby button does not help.
        Will go home and connect up the box to try, but is my box kaput if it is stuck at the current state?
        • yes99
          • Apr 2012
          • 5
          #544
          Did the mod remove the st@rh#h thread? Cannot find it anymore
          • twiddlebug
            • Jul 2013
            • 4
            #545
            can only get free to air channels now....read its due to no keys n scce, I copied the 2 folders from my other box into the revived one, but like cannot....any advise from seniors here?
            • WhoIsGad
              • Jul 2013
              • 8
              #546
              Now i know..i was like trying to figure out what the hell is Sun, fat pipe, etc.. slowly but surely learning the ropes.
              Originally posted by ahbenghero
              To all the newbies,
              Please mind the stuff you are posting.
              Firstly, we all started out as a noob, knowing nothing and learning stuff along the way. You need help, post in the relevant topics. You have questions, ask nicely!! How will you feel if somebody ask you for favor in real life AGGRESSIVELY/ARROGANTLY?!?!? I quote an example "I have a dm800hd se not a 500c, whenever thread this is everyone has a problem that is needed to be solved, if not for me then someone else will ask something else, so better to help find a solution so we all can carry on our lives... " For your info, Even if you never ever find a solution, our live still carries on. =))
              Secondly, Do not expect to be spoon-fed, this way you will learn nothing. Try to figure it out on your own first, if there are things you are unsure of, use the search button first. You will realize there were alot of repeated questions and answers to it. More often that not, the questions you have can be found. DON'T BE LAZY!!!
              Lastly, please refrain from posting KEYWORDS in full ie. our country and our service provider. Because they can easily be found using online search engine.
              P.S: Openly Discussing Keys and Roms are strictly prohibited in this forum.
              • windeleon
                • 11
                #547
                Thanks alot ts
                • uu1231
                  • Jan 2013
                  • 7
                  #548
                  I am using 800HD and have updated the channels using DBedit. I noticed some channels such as 155 and 468 etc. have Tuned Failed error. For 468, it works sometimes. Is this an issue with the cable signal? I do not think it is an issue with the parameters as all of us are using the same. In general, most channels work fine but 155 never works. Thanks.
                  • uu1231
                    • Jan 2013
                    • 7
                    #549
                    Sorry wrong info. 468 food network asia hd works with no issue. It is 433 food network asia and 155 hd5 does not work. Do you have the same issue?
                    • AVGAL
                      • Jul 2011
                      • 64
                      #550
                      For me, I can't get 402 on my 500c.
                      Tried all bouquet provided here, but still dont have.
                      • garlic
                        • Jul 2010
                        • 22
                        #551
                        Go to the first post of this thread and download the Bouquet from the link provided. I just update my DM500c and 402 works as with all channels.
                        Much thanks to TS.. thank you.
                        • ASTROBOX
                          • 163
                          #552
                          Should be no problem if you used the channel list from 1st page that i upload on the 6th jun for 500C & i just upload for those E2 box that include the new channels
                          463 Crime & Investigation Network HD
                          464 The Biography Channel HD
                          562 WarnerTV HD
                          755 BBC World News HD
                          760 CNN HD
                          This new bouquet does not have lock icon if you're open using DB Edit however there is no Demand Channels
                          • creative00
                            • Feb 2011
                            #553
                            whats the frequency for ch 402, 514, 836 and 861?
                            and how come i cant download the bouquet ?
                            • yes99
                              • Apr 2012
                              • 5
                              #554
                              just got a new dm500c from china. They don't seem to able to give me the password.
                              Do i need the password in order to ftp keys/scce and play with the box?
                              • jatrophaseed
                                • May 2010
                                • 589
                                #555
                                Funny, pls post which dealer in China u get from, I know China DM500C all NOT PW lock!!!! This dealer is definately commiting business suicide.
                                Post their website if it is bought online.
                                Bro, I know in China certain unwritten Pirate Rules r followed, they dont break them juz for Sg. eg. Those sell to Sg had Mgcamd installed ealier then they find these boxes cannot b sold to other countries, so now they only put in the KEYS juz to view Sg chn, no mgcamd. but all DB boxes hv std CCam2.1.4 and nothing else bcos other countries dont need mgcamd, or hv different mgcamd config.
                                I know bcos I supply PCB to them earlier but now business sold bcos I too old. I mean my factory in CHINA lah.
